stock carb jetting
- GargantuChet
Re: stock carb jetting
02 Nov 2005 09:48
jdevoe wrote:
I'm assuming that you're looking for the naming so you can try to track the part down. You can find Kawasaki's part names and numbers from a couple of sites:
Search for your bike on buykawasaki.com . Choose Owner Info (second line of options at the top), then Parts Diagrams. Entering a VIN won't work unless your bike is post-1986, so choose Motorcycle -> Continue and search for your bike.
It's probably easiest just to select "650 Custom" on the right, hit Continue, and click on 1977 from the list.
Bikebandit.com also provides access to these diagrams, and you can order parts right from the diagram if you want.
Z1 Enterprises is a popular site around these parts. Jeff, who runs Z1, also frequents this site, and is a darned nice guy from what I can tell. If you can figure out what you need to get, Z1's prices are usually quite competitive and Jeff has a good reputation.
do you have the nomenclature that corresponds to the #s on the diagram? thanks for the post also it is what i was looking for
- jdevoe
02 Nov 2005 10:30
On the above picture were do the 2 #35 hoses connect i know #33 goes to 1 port on the petcoc and i belive 43 goes to the other
- jdevoe
02 Nov 2005 10:33
By the way i would just like to thank you all for all the help i would be lost without this site sometimes
- wiredgeorge
02 Nov 2005 12:23
Connect vacuum line to petcock and vents should have hoses that are not pinched/obstructed. See picture for locations.
- jdevoe
