PO is a jerk...camshaft bolt holes stripped...
  • RsvBruno
  • RsvBruno's Avatar Topic Author
02 Sep 2010 07:11
#395574
Well, here's my rant. If you strip something INSIDE the engine, and its a pretty important part...oh say the bolts that I have to use to hold my camshafts down and tight, and then you bolt the motor back up and say it ran fine last year when I parked it...you are a jerk. Anyways, what I thought may be a simple job, like clean the carbs, check valves etc. has turned out to be much more fun. I have a 1981 KZ1000 LTD that has 2 bolts stripped out on the camshaft brackets (not sure what to call them) this is obviously something I don't want to leave as-is. So could anyone tell me if they have had any luck doing a time-sert or heli-coil in one of these places, or if there is room to drill a tad lower maybe and get a longer bolt? Any help would be appreciated. Been lurking on here far too long so I thought I'd post up and see what you guys come up with. Thanks in advance.
Bruno
1981 KZ1000K
1977 KZ650C1
1976 KZ750B
1980 KZ440LTD
  • 9am53
  • 9am53's Avatar
  • homebrew, and some bbq
Re: PO is a jerk...camshaft bolt holes stripped...
02 Sep 2010 07:15
#395575
When I saw the title of this thread it was obvious what bike you have... this is really common in this bike because the manual has a big error in it and states to tighten those bolts to 12 foot pounds...I stripped 2 in my head last winter. I put helicoils in and have been fine ever since. I will be putting in new cams this winter and was thinking of putting helicoils in the rest of the holes as well for safeties sake. Many people will tell you helicoils suck and to use the time serts...they are likely better but I am happy with the helicoils.
  • RsvBruno
02 Sep 2010 07:22
#395578
Do you by chance know what size heli-coil I should be getting? That would help a ton so I can search around here for one. Now I feel a LOT better about this! You may have just added a few years to my life by stopping the pounding and blood pressure spike that stayed from last night! haha.
1981 KZ1000K
1977 KZ650C1
1976 KZ750B
1980 KZ440LTD
  • Motor Head
  • Motor Head's Avatar
02 Sep 2010 07:25
#395579
Personally I would do the step stud repair. They are available in different sizes, this link has them at the right hand side of the page. Any local machine/ engineering shop should have some.
www.belmetric.com/html/catalog10.htm
  • otakar
  • otakar's Avatar
02 Sep 2010 07:25
#395580
They are called "cam bearing caps". You might want to give the PO a little brake. This is a common problem and it is Kawasaki's fault. They have the wrong torque listed in the service manual. many of us have stripped the cap threads in the head. Installing "quick-serts" or "Helicoils" has been covered many-many times on this web sight. so don't feel bad, you are not the only one in this boat. Yes, I have done it also. In the book it states that the torque should be 12 lb/ft when in fact it should be only be 105 oz/in.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • RsvBruno
02 Sep 2010 07:32
#395584
I'll give him a break for doing it...but not a break for buttoning it up and hoping that the motor doesn't destroy itself for the next person...NOT COOL. But again I feel WAY better about this now and its not like I was going to contact him and yell, I enjoy learning how to fix various problems really, just not a dishonest person. I've read tons of the threads on "how-to's" for these heli coils and such, just thought I'd get opinions and let off some steam. Thanks for helping me with both! :P Anybody have the size handy?
1981 KZ1000K
1977 KZ650C1
1976 KZ750B
1980 KZ440LTD
  • otakar
  • otakar's Avatar
02 Sep 2010 07:35
#395585
No eBay APP ID and/or Cert ID defined in Kunena configurationThis is a very inexpensive way to fix those.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • RsvBruno
02 Sep 2010 07:38
#395586
Otakar I think I've seen you in a few of the forums I'm on (I have a few bikes) and you are ALWAYS a life saver. THANKS! :woohoo:
I'll let you guys know how it goes later tonight.
Bruno
1981 KZ1000K
1977 KZ650C1
1976 KZ750B
1980 KZ440LTD
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
02 Sep 2010 07:50
#395589
Yep, I have one of those bikes too (the GPz1100 had 8 stripped cam cap holes...the PO never said a word :laugh: ) I used Time-Serts...pricey but they work.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • RsvBruno
02 Sep 2010 07:53
#395591
Why the eff can't people just be honest. Oh well. I guess we all learn while doing, and now my 2 stripped cam cap holes make me feel Lucky. What a turn around from this morning eh? Glad I joined this forum! I practically own almost every KZ now...so I thought I should! haha
1981 KZ1000K
1977 KZ650C1
1976 KZ750B
1980 KZ440LTD
  • 9am53
  • 9am53's Avatar
02 Sep 2010 07:53
#395592
those that otto linked are the ones I used.
  • otakar
  • otakar's Avatar
02 Sep 2010 08:44
#395599
M6x1.00
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
