cam wheel question
- oldster
cam wheel question
17 Aug 2010 04:28 - 17 Aug 2010 04:32
hi,advice please! my stock camwheels are suffering from the rubber pads breaking down,is it ok to remove all the rubber and keep using them ??? cheers oldster.forgot to mention bike is an z900.
Last edit: 17 Aug 2010 04:32 by oldster. Reason: forgot to list bike model
- larrycavan
Re: cam wheel question
17 Aug 2010 04:53 - 17 Aug 2010 05:05
oldster wrote:
Are you referring to the cam sprockets themselves or the idler wheels?
The idler wheels should be replaced if the rubber is deteriorating. It's most likely time for the cam chain to be replaced as well.
Liska idlers can save you money over OEM idlers. I use them all the time in rebuilds.
Larry C
Larry C
Last edit: 17 Aug 2010 05:05 by larrycavan.
- oldster
17 Aug 2010 06:42
hi,its the actual sprockets on the cams,am scared that some of the rubbers going to fall off into motor, it's already breaking up !
- zed1015
17 Aug 2010 13:55
It's ok to remove the rubber. It's only there to quieten the camchain.
Aftermarket sprockets don't have it at all.
Just remember to put a center pop mark to identify the inlets 28 pin mark for future timing checks.
