- Thank you received: 15
Valve adjustment question...
- madmatt1
Thanks for all the help so far to everyone!
1977 KZ1000 LTD
1977 KZ1000A
- MFolks
- Thank you received: 540
A little corrosion on the bullet connectors can lower output voltage to the charging system.
The next place I'd check would be the mating connectors at the regulator/rectifier. On some earlier Kawasaki's they were seperate modules.
The handle bar switches(both left and right) need inspection for corrosion too. The right one has the run/stop and start switch, the left one the headlight,turn signal and horn switches.
The headlight will need to be removed to check the connectors inside the housing; I'd disconnect one connector, spray it with a good electrical contact cleaner(NOT WD-40!!) and reconnect it moving on to another.
I use a very good brand of electrical contact cleaner/preservative called "De-oxit" on my bike's many and various electrical connectors. www.deoxit.com is their website.
The spray can be purchased at Radio Shack Stores in the U.S. or at any electronic supply places.
- Thank you received: 2098
...been fouling up plugs. The carbs were just redone, jetted up one size...bike runs great with clean plugs, idles nicely when warm. I use the choke extremely sparingly, and don't do a lot of idling. But the plugs are so sooty after the last 1000 miles I put on, that it started to run pretty crappy....
Patton wrote:
...Would also assure fuel levels inside float bowls are correct (especially not too high) by performing the clear tube test.
Too high fuel level can cause overly rich mixture even with otherwise perfect carbs, perfect compression and valve clearances, and perfect properly timed spark....
madmatt1 wrote:
...carbs were rebuilt by a shop in my area...float levels were supposed to have been set....
Trust, but verify .
Would confirm fuel level via clear tube test.
- MFolks
1.Sparkplug caps can fail as they have an RFI surpression resistor inside that may be comming intermittent. I'd replace them.
2.Sparkplug wires get heat aged and may open up the insulation when hot, weaking the spark. 7mm non resistive sparkplugs wires are available from z1 enterprises for greater spark energy.
- TeK9iNe
- What did you do!?!
- Thank you received: 28
Put the smaller size pilot back in and tune your mixture screws correctly.
If referring to main jets, then dissregard.
Also... a sync is only temporarily done, if not performed with a manometer while engine is running. Bench syncs suck...
To check sync: Get engine idling off choke, then lower idle down to point where its almost stalling. After a couple minutes, 1 or more of your pipes will get cool from not recieveing enough fuel charge from the carbs.
If this is the case, then a vacuum sync is absolutely necessary.
GL.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
