Valve adjustment question...
12 Aug 2010 12:05 #390356 by madmatt1
Valve adjustment question... was created by madmatt1
I was measuring my valve clearances last night on my 1977 KZ1000, and the results puzzled me. I bought this bike over the spring, and have put about 2500 miles on it since then. Everyone has told me to check & adjust the valves if necessary every 4-5 thousand miles. I am guessing that they weren't adjusted anytime soon before I bought the bike because the previous owner did not seem to be real dilligent on maintanence. I checked the clearances and none were less than .08 mm, most were right at .10 mm, and two of the exhaust valves were actually just a touch over .10.
I don't understand how that could be and I'm wondering if I'm doing something wrong. I checked them all by lining up the marks on the cam sprockets with the top of the head, so that the top of the cam lobes faced either up or on an angle AWAY from the valve itself. Then I'd rotate the crank a full turn and measure the other pair. Is this correct, or is there a better way?
1977 KZ1000 LTD
1977 KZ1000A
  • testarossa
12 Aug 2010 12:44 #390363 by testarossa
Replied by testarossa on topic Valve adjustment question...
Sounds like you are following the correct procedure for checking. How much do you know about the PO? Is he the original owner? If not then how long did he have the bike? A lot of stuff can happen in 33 years. I doubt that those are the original shims since some are a little over the original high spec of 0.1mm. I believe that the spec was later revised to 0.05 - 0.15 mm. I would just be happy and run it as is. Are you experiencing any problems?
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • TeK9iNe
  • What did you do!?!
12 Aug 2010 12:48 #390365 by TeK9iNe
Replied by TeK9iNe on topic Valve adjustment question...
Agreed. Sounds like everything is fine.
.05 - .15 mm is good.
Are you pressing the feeler guage flat against the shim first, then trying to slide it between? If so, then I'd say you're good to go. Button up and ride ;)
GL.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
12 Aug 2010 13:15 #390377 by madmatt1
Replied by madmatt1 on topic Valve adjustment question...
I don't really know too much about the previous owner, except that everything other maintanence item on the bike was not maintained very well. I went after the valves because I've been fouling up plugs. The carbs were just redone, jetted up one size, I run a MAC 4-1, Dyna coils, ignition and wires. The bike runs great with clean plugs, idles nicely when warm. I use the choke extremely sparingly, and don't do a lot of idling. But the plugs are so sooty after the last 1000 miles I put on, that it started to run pretty crappy. I'm thinking that I should be going after my electrical system to make sure I'm getting enough voltage?
1977 KZ1000 LTD
1977 KZ1000A
  • testarossa
12 Aug 2010 14:43 #390397 by testarossa
Did you recently fuel up at an different location than normal? Or is the 1000 mi plug fouling consistent? I think that it would be worth your time to check the voltage at the coils.
2004 ZX-10R
Angola, IN
12 Aug 2010 15:00 #390401 by madmatt1
it is consistently sooting up plugs. not really any signs of oil either. I just dont see how it could be running so rich with only one size up jets and running a 4-1...thats whats making me think my spark isnt hot enough. what is the voltage at the coils supposed to be?
1977 KZ1000 LTD
1977 KZ1000A
  • testarossa
12 Aug 2010 18:54 #390476 by testarossa
It should be 14-14.5v at 4000rpm. If its less then I would check the battery. If the two are different, then inspect the wiring for corroded connectors, cut insulation, frayed wires, loose connections. If they are the same but lower than the 14v then I would suspect the charging system is at fault.
2004 ZX-10R
Angola, IN
12 Aug 2010 19:15 - 12 Aug 2010 19:20 #390484 by Patton
Replied by Patton on topic Valve adjustment question...
A basic spark quality check is by visual inspection of spark on plug tips while spinning over the engine with plugs removed and their bases held grounded against the engine head.
Look for fat blue sparks.
Would also assure fuel levels inside float bowls are correct (especially not too high) by performing the clear tube test.
Too high fuel level can cause overly rich mixture even with otherwise perfect carbs, perfect compression and valve clearances, and perfect properly timed spark.
Good Fortune! :)
Last edit: 12 Aug 2010 19:20 by Patton.
12 Aug 2010 19:30 #390488 by Patton
Could also experiment by leaning the carb pilot circuits, say 1/2 turn on each adjuster screw.
Stock carb has bottom-located pilot mixture adjusting screw on engine side of carb. The screw turns in clockwise to get leaner mixture. And would turn out counter-clockwise to get richer mixture.
Where carb has side-located pilot air adjuster screw on airbox side of carb, turn in clockwise to go richer (allows less air) and turn counter-clockwise to go leaner (allows more air).
Good Fortune! :)
[Click on image to enlarge view.]
13 Aug 2010 04:59 #390555 by BSKZ650
Replied by BSKZ650 on topic Valve adjustment question...
if you went one step richer, from what,, possible someone had already done that and you just went farter? what size did you install?
77 ltd1000, current rider
76 kz900, just waiting
13 Aug 2010 05:07 #390557 by Patton
For reference, stock VM26SS Mikuni carbs have 107.5R main jets and 17.5 pilot jets (per FSM).
Good Fortune! :)
  • testarossa
13 Aug 2010 05:19 #390558 by testarossa
This is a very good point. I assumed that you knew that the jetting was correct. Silly me. It could also be worth a look in those float bowls to see what size jets are really in there if you don't already know. I think that MAC advertises that you don't need to re-jet for their 4 into 1. It is possible that you are just a little rich on those jets.
2004 ZX-10R
Angola, IN
