- Thank you received: 5
KZ750 noob engine disassembly - what work to do?
- staniel
For me they honed all four, yes, and everything's copacetic. You said you have standard piston rings.. I would have bought those in a heartbeat but it's too late. $185 later, I have a set that the shop ordered for me.
You don't happen to have pin circlips, do you? Or know of a place in the US to get them? All the places I've looked seem to be shipping overseas and the Kawasaki dealer wants $35 for 8 of them and a seat damper.
1983 KZ750 L3 with 4-1 Kerker pipe and pods
1983 KZ750 L3 parts bike
- Brown Bear
staniel wrote:
GLORY day!
I got a call from the shop today. The bump honed out. I need a new set of piston rings (original size), but that's pretty much it from here.
So, why do you need the cylinders honed if they have already honed them? Surely they didn't hone just one cylinder?
I'm pretty sure I have 4 sets of new standard 750 rings around here somewhere.
If you can't rotate the crank to move the pistons up then the cam chain is probably wedging the crank at the bottom. Pull the cam chain up.
would these for sets of rings fit the z400j? they must all be the same?
- Brown Bear
- steell
Steell, I think you've got me and Brown Bear mixed up
That's the problem with a thread hijack, things get confusing :laugh:
No new ones, only used ones, and you really don't want to use old circlips, they do a job on the cylinder walls when they come out. Spend the $35.
- staniel
Buying feeler gauges tomorrow to check valve clearances, even though I won't get to that point for a while. I wish I had more guidance on how to put a gasket on very securely and could see exactly how clean a surface needs to be before proceeding. I don't think I can get any farther with gasket cleaner and a razor. Sandpaper seems a bad idea except on the area I gouged.
I love this forum. It's nice to have a little diary of my project with intermittent advice from knowledgeable folks.
- Brown Bear
- staniel
Is all that black stuff gasket material I need to remove? It's the same color as the engine... someone please tell me it's just the enamel they used. That stuff is not coming off...
- 9am53
- homebrew, and some bbq
- Thank you received: 3
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
- staniel
I started going at it with the razor and I think it's starting to come up. Total PITA (I picked this acronym up on this forum ).
Did you take any pictures of the finished surface after you'd scraped it? Obviously it won't be as nice as having it machined, but no one would be able to machine this in-frame...
- 9am53
and here are some after shots, the bottom of the jugs was just as bad
that literally took me a few days of straight scraping, you get cramps and shit, it's not cool, but needs to be done - I have no leaks at any gaskets now.
And btw, I recommend getting a ball hone, it's cheap and really easy to use and did a great job deglazing and renewing my bores
'84 GPz900r
'71 CB350
- Brown Bear
i thought they only did the 3 arm type?
- 9am53
Corey Clough was present in the early goings of my thread and was instrumental in my purchasing and using a ball hone:
kzrider.com/index.php?option=com_kunena&...mit=20&limitstart=40
somewhere in the middle there corey gives a couple links to more info. The brand name you want is flex-hone, they have sizes ranging from brake master cylinder bore sizes all the way up to richard simmons' "bore" size, I got mine on eBay for like 30 bones, and I have it sitting in a coffee can full of oil for next time
'84 GPz900r
'71 CB350
