- Thank you received: 5
KZ750 noob engine disassembly - what work to do?
- staniel
I've been reading through the thread "A Newbies Adventures in Maintenanceland!" and have loved it, but now I'm starting my own, probably much simpler one, as the unemployed have additional constraints to worry about...
All of this is happening because I had a leaking head gasket on my KZ750-L3, and a shop said "if we replaced that, we might as well do xxxxx.. and it'll run you up to $2k real quick," so I thought I'd do as much of the work myself as I could. I don't want to futz with valve seals or grinding any metal down into to specified tolerances, so I'm going to outsource any of that that I have done.
I pulled the head off yesterday, which was a blast. I'm looking at the pistons and they're nasty, and the spark plugs are blackening on the threads (got carbs rejetted recently) but I don't see anything obviously awful in there. Shiny where it ought to be, gunky on the outside.
I just ordered a full gasket set from Z1 Enterprises [again, per forums here] and I'm ready to take stuff apart and put stuff back together, but I want to be smart about it - not pulling stuff off that I don't need to.
What work would y'all suggest I do to maximize the life of this machine while minimizing pains in butts? Take the head and block to a shop, get the valves done, hone the cylinders? New piston rings need to be done myself if I don't take the crank case to the shop?
My roommate took some fancy pictures of the ordeal. I'll see if I can get 'em up here.
1983 KZ750 L3 with 4-1 Kerker pipe and pods
1983 KZ750 L3 parts bike
- steell
I'd have a better idea of what work might need to be done if I knew the mileage of the motor
- staniel
- bountyhunter
- Thank you received: 337
Probably just needs a valve job and seals. Mine didn't need boring until 75k miles. However, I wouldn't say a hone and new rings would be a bad idea if you are inclined.That's a good question. Instead of trying to answer it, I'll tell you the information I have: I bought it from a friendly guy who was able to answer some of my questions. It had 14k on the odometer, but the odometer was not working at that time. I hooked it back up right away. He said he didn't ride it much and that it hadn't been that way for long. The gas gauge also didn't work and eventually my whole console collapsed. I replaced it with a speedo from the internet and now it says 37k
- staniel
I'm gonna try to find a car and take the head and block to my favorite motorcycle shop (Jim's Southend in Burien, WA). I'll ask them to do what seems appropriate on the valves and hone the cylinders as well. Should I pop the pistons off and have them measure them up for possible new rings as well?
..I'd really love my mileage to be better than 37 actual.
- bountyhunter
The rings for the four cyl bikes are pricey. Too bad it's not a 750 twin, new piston/ring sets are dirt cheap like $60 each. It's really a question of how much cylinder wear you have. you can feel it by sliding your finger along the wall and check for the ridge at the top where the piston travel stops. If not much, pistons and rings are probably good.I certainly am inclined!
- bountyhunter
I have seen sets that CLAIM they come with seals but really don't... COUGH! ATHENA! COUGH!I have never seen a 750 four full gasket set that included seals, so don't forget the extra $30-$40 for those.
Get some VITON seals. For a few more bucks they are way better material and last a lot longer.
- staniel
For some reason it's much easier to spot it in the picture when it's rotated to be on the top, but here it is (at about 12:05 o'clock). In the cylinder it looks much darker than it does in the picture.
Any idea what that's about? Is the piston moving strangely at the bottom of its cycle? Will new piston rings and honing solve this problem so it doesn't come back? Why is it only the one cylinder?
I'm so excited to be doing this. I'm taking the head in for inspection. I half expect them to tell me there's too much carbon on the valves, as the pistons are nasty.
- steell
Actually I was talking about crank seals, trans output shaft seal, shifter seal, etc. Vesrah includes the valve seals, but not the others.
- TeK9iNe
- What did you do!?!
- Thank you received: 28
Dont regret not doing it 10k from now...
GL.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- 9am53
- homebrew, and some bbq
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
- staniel
I took the cylinders and head to the shop today. The genius mechanic for whom the shop is named said "it looks like rust" (it's not red, but he knows more than I do and it sure looks metallurgical) and "I doubt it'll hone out and we'll probably need to bore it, but we'll try first".
He laid that out for me, that the bore is $50 per cylinder and a set of new pistons runs around $500. This is well out of my price range when stacked on top of the valve work they're gonna do, so if it doesn't hone out, I'm in a tough spot.
How bad an idea is it to ride with a dent like that in your cylinder if you get new rings? Am I damning by bike forever if I do it? Have any of you ridden with obvious chunks (visible, pads of fingers can feel it, but very very shallow) in your cylinders?
