- Thank you received: 20
low compression in one cylinder,
- nads.com
- nads.com
- Old Man Rock
- Thank you received: 225
Here's why I say this....
Had my head work accomplished by the man himself, Larry C.... Now Larry had informed me from the beginning, replace the valves regardless... Unfortunately being a dumb ass and tried going cheap, I didn't listen... :blush: Yeah I know, I know...
NOTE: My issue as being depicted below had NOTHING to do with Larry or his work!!! This was totally out of anyone's control and if anything, it was MY DOING!!!
Within/during the first 6 months, the engine smoked more then expected and in my engine break in periods, during my valve clearance measurements I found #1 exhaust would not hold it's clearances like the others.... WTF you say.... Swapped out the shims twice and same thing each time I measured...
Contacted Larry and informed him my bad, just let me know the costs after inspection, I was sending the head back with new exhaust valves and OEM seals. Yup, tried going cheap on the seals originally as well... Stupid MF I was....
See, when I didn't carefully listen to the man, upon initial inspection, the intake valves were shiza and required replacement... Larry Informed me the exhaust seemed ok but based on experience alone I should replace them especially based on intake conditions... Well of course didn't listen (I've since learned to listen to the man) I got cheap (dumbass) and said ah shit, leave them in.... :blush: :pinch: :whistle:
Learned the hard way, something was just not right about that #1 valve, just wouldn't seat properly.... Replaced with new Kibble White valves and OEM seals, Larry performed his magic and in 2500 miles (4000 miles total now), clearances as expected and no smokey...
Little 1015cc w/performance cams & 29mmm CR's pulls like a mo foe.... :evil:
Sorry for the long story all but it's totally true at that... Sometimes these old valves and head components have seen their time... Just crap after 30 years of abuse.... As explained to me by Larry, they can go soft, they can slightly deform when hot, they can be some after market unknown crapola... who knows for sure...
Just my 2 cents anyways... Hope you get it resolved...
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- larrycavan
- Visitor
If injected, the most likely suspect is the ECU or a bad wiring issue.
There's code light on that system. Little light on the ECU itself that will flash. Codes are in the GPz11 supplement service manual.
Make sure you have a good ground.
- BSKZ650
- Thank you received: 14
my 2 cents, I would get the head redone this way you know everything is right when you go back this time
77 ltd1000, current rider
76 kz900, just waiting
- roccbottom
- 1984 gpz1100, 1995 kz1000p
- steell
Now after having no compression before getting the cams lined up correctly, set the cams to have the following numbers from the cylinders,#1-120 #2-100 #3-140 #4-150. added the cap full of oil,compression didn't change.
You added a cap full of oil through every spark plug hole and didn't get a increase in compression??
That's crazy! Almost 50 years of turning wrenches and I've never seen such a thing. Four cylinders with oil added and none came up in compression?? Go get another Compression tester.
A bench sync only gives you a starting point for a vacuum sync on the bike.
BS34's? I'd physically check the throttle blades to see if they are actually wide open when the throttle is.
- larrycavan
- Visitor
I assume he added oil to the low reading clyinder, not all 4.....but hey...ya never know. But, be that as it may, if it's a valve problem the oil isn't going to raise compression anyway.
- PLUMMEN
- Thank you received: 104
- roccbottom
- larrycavan
- Visitor
Man thats funny right there I dont care who you are. no just the # 2 cylinder didnt rise. accept my apology for not specifying which cylinder it was.I know it can be a pain,when you try to help,but only have partial information.After talking to you guys.I most likely will start rebuilding it after the parts arrive, so I wont have the same problems occur. should I have the head redone. or just replace all the other parts in the head?
If you can take the head apart yourself, here's what to do.
Remove the old valves. Clean the valve seats up with brakeclean.
Clean the new valves with brakeclean.
Take a blackmagic marker and paint the 45 cut on the valve with it.
Before it dries, poke the valve down in the guide and seat it. [use a lapping stick]. DO NOT SPIN IT!
Pull the valve out and inspect how the marker transferred to the seat. If it's a perfect seat, the marker should stick and you should see a nice black line all the way around the seat.
Post pictures if you can. Hard to analyze what you can't see...
- PLUMMEN
Larry works as a motorcycle psychologist/therapist,hes always got a kz motor laying on his bench/couch talking about its traumatic childhood at the hands of some speed freak! :woohoo:roccbottom wrote:
