low compression in one cylinder,
- roccbottom
- 1984 gpz1100, 1995 kz1000p
- bountyhunter
- Thank you received: 337
old rings? new rings? Oversize rings?and cylinder honing done
- porchev914
- Thank you received: 19
FRANKEN Z!
- roccbottom
- larrycavan
- Visitor
guys please help me out, heres the run down.had a valve job and cylinder honing done,valve adjustment and corrections done, valve timing set,carbs synced.added new spark plugs,and wires,Now after having no compression before getting the cams lined up correctly, set the cams to have the following numbers from the cylinders,#1-120 #2-100 #3-140 #4-150. added the cap full of oil,compression didn't change. so i tore the top half down once more.hoping to find something broken or out of place. no such luck.B.T.W/ it's my 84 GPz 1100. where should i begin looking? or is it just time to purchase another engine..
Are you saying you had the cams mistimed at one point?
Based on that "assumption" and the fact that oil didn't raise the PSI, I would suspect you may have tagged a valve in the low cylinder. Try pouring liquid in the ports and see if they leak.
- BSKZ650
- Thank you received: 14
what was causing it to shut down?
77 ltd1000, current rider
76 kz900, just waiting
- roccbottom
- dshelly
- Thank you received: 5
Occupation:Machinist 25+ exp.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
- mark1122
- Keep twisting it
- Thank you received: 109
added the cap full of oil,compression didn't change. :
This would be a strong symptem of a poor valve seating. if u add oil u seal the rings, if compresion does not change, then u must suspect the valves. likely a bent valve or poor seat.
follow Lary's advice and check that the valve will hold penatrating oil.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- roccbottom
- TeK9iNe
- What did you do!?!
- Thank you received: 28
Make sure every valve is perfect, and with the head upside down, fill the valve area "bowls" with gasoline. If it leaks past a valve it will need to be lapped.
Install the head.
Cams must be installed/timed correctly and hand turn over motor slowly to ensure no valve/piston contact.
Your cams are probly fine.
If a shop did the work prior, demand a refund or the work be done properly.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- bountyhunter
Did they straight edge the head and cylinder surfaces to make sure they are not warped?okay guys, wiped out the bottom of the head. poured some wd 40 in each cylinder,nothing leaked out.just guessing here: but could my cams be bad?
