low compression in one cylinder,
  • roccbottom
  • Topic Author
  • 1984 gpz1100, 1995 kz1000p
05 Jul 2010 20:44 #380508 by roccbottom
low compression in one cylinder, was created by roccbottom
guys please help me out, heres the run down.had a valve job and cylinder honing done,valve adjustment and corrections done, valve timing set,carbs synced.added new spark plugs,and wires,Now after having no compression before getting the cams lined up correctly, set the cams to have the following numbers from the cylinders,#1-120 #2-100 #3-140 #4-150. added the cap full of oil,compression didn't change. so i tore the top half down once more.hoping to find something broken or out of place. no such luck.B.T.W/ it's my 84 GPz 1100. where should i begin looking? or is it just time to purchase another engine..:unsure:
05 Jul 2010 21:07 #380513 by bountyhunter
Replied by bountyhunter on topic low compression in one cylinder,
Valve clearance. Bent valve. broken ring
old rings? new rings? Oversize rings?
  • porchev914
05 Jul 2010 21:23 #380516 by porchev914
Replied by porchev914 on topic low compression in one cylinder,
Was the engine run in and the new hone/rings seated?
FRANKEN Z!
  • roccbottom
  • Topic Author
05 Jul 2010 21:30 #380518 by roccbottom
Replied by roccbottom on topic low compression in one cylinder,
new stock rings,engine would run about 30 and shut down,
  • larrycavan
  • Visitor
06 Jul 2010 05:03 #380543 by larrycavan
Replied by larrycavan on topic low compression in one cylinder,
Are you saying you had the cams mistimed at one point?
Based on that "assumption" and the fact that oil didn't raise the PSI, I would suspect you may have tagged a valve in the low cylinder. Try pouring liquid in the ports and see if they leak.
06 Jul 2010 11:28 #380582 by BSKZ650
Replied by BSKZ650 on topic low compression in one cylinder,
Im with Larry, but have a question, if it would only run for a short time, how did you snyc the carbs?
what was causing it to shut down?
77 ltd1000, current rider
76 kz900, just waiting
  • roccbottom
  • Topic Author
06 Jul 2010 14:39 #380618 by roccbottom
Yes the cams were mis-timed at one point.the carbs were bench synced. fuel was provided by a temporary fuel source. it started up ran for a good moment.then shut off, it could be immediately restarted run for a short time shut off. reason for shutting down is unknown to me. it has strong spark, its getting fuel. I dont know?
06 Jul 2010 14:46 #380619 by dshelly
Replied by dshelly on topic low compression in one cylinder,
Re-Check your Head bolt torque. If that's OK try doing a leakdown test. That will tell you if a valve or ring got messed up.
Occupation:Machinist 25+ exp.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
  • mark1122
  • Keep twisting it
06 Jul 2010 15:21 #380625 by mark1122
Replied by mark1122 on topic low compression in one cylinder,
roccbottom wrote:
added the cap full of oil,compression didn't change. :
This would be a strong symptem of a poor valve seating. if u add oil u seal the rings, if compresion does not change, then u must suspect the valves. likely a bent valve or poor seat.
follow Lary's advice and check that the valve will hold penatrating oil.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • roccbottom
  • Topic Author
06 Jul 2010 15:27 #380626 by roccbottom
okay guys, wiped out the bottom of the head. poured some wd 40 in each cylinder,nothing leaked out.just guessing here: but could my cams be bad?
  • TeK9iNe
  • What did you do!?!
06 Jul 2010 15:39 #380631 by TeK9iNe
Replied by TeK9iNe on topic low compression in one cylinder,
Take the head off and inspect it thoroughly and properly.
Make sure every valve is perfect, and with the head upside down, fill the valve area "bowls" with gasoline. If it leaks past a valve it will need to be lapped.
Install the head.
Cams must be installed/timed correctly and hand turn over motor slowly to ensure no valve/piston contact.
Your cams are probly fine.
If a shop did the work prior, demand a refund or the work be done properly.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
06 Jul 2010 18:20 #380681 by bountyhunter
Did they straight edge the head and cylinder surfaces to make sure they are not warped?
