- Thank you received: 391
Copper filings on oil filter base.
- Motor Head
Hope you can fix it and still make the trip, hate to plan for a year and not go!!
- hardr0ck68
- Who put the what in the where?
Maybe it was the remains of a previous engine problem, maybe the neighbor kid put a penny in your oil fill... who knows but if there is no problem then hey, there is no problem!
I agree with wireman for once!
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
- porchev914
- Thank you received: 19
I'll look around myself this evening (right now I'm committed to some time with my wife), but are you guys sure the big end bearings are rollers?
Absolutely certain they are roller bearings.
FRANKEN Z!
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- Galactica
- Thank you received: 2
It's an interesting issue though. I'll post my findings and pics next week.
77KZ1000
76 KZ900
- PLUMMEN
- Thank you received: 104
dont ruin your perfect record on my account :SIf there is no odd noise and the oil light is staying off I would ride it and flush the oil....
- hardr0ck68
Hey even a broken clock is correct twice a day right?
1977 kz650 c1
- nads.com
- Thank you received: 20
Why arent cranks made with babbit bearings and pressed together parts? The you could replace damaged journals and youd have the high rpm sometimes sought after.110% certain they are roller bearings on a pressed crank.
- testarossa
- Thank you received: 82
nads, I think that you have to look at it as an engineered system. First, in 1975, 10,000rpm was pretty hot. Second, it's not just the main bearings are not the only limiting factor on the redline. Two valve heads can't breath very well at the top end, and still be streetable. Even if you do use huge valves to breath up top, then you have to run high valve spring pressure to control the valve float. This is hard on camshafts and timing components like cam chains etc. Mother Kaw had to make a decision about performance/durability and in the 1970's they definantely erred on the side of durability. It's the whole reason that we laud the KZ for being reliable, and still ride 30 year old bikes all over the country to this day. If you want a motor that you can rev to the moon, then go get any newer 600 cc sportbike. Most of them redline around 17,000 rpm and make more hp than your KZ, and come with a warranty. Will they last 30 yrs? Not likely.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
- hx35w
- Thank you received: 5
- dragsta
how many miles are on your engine?
how often do you change the oil?
i think you are worrying too much.
- Galactica
I just got back form a 600km (400mi) ride. Just waiting for it to cool down, then I'll drain the oil and have look.
She ran flawlessly until I pulled into the garage and I saw fuel pissing out of the #3 carb overflow. I quickly shut off the petcock, drained the bowls, removed the #3 bowl (damn it was hot), flicked the float a coupla times, reassembled, and voila problem solved
77KZ1000
76 KZ900
