Copper filings on oil filter base.
01 Jul 2010 20:38 #379577 by Galactica
Copper filings on oil filter base. was created by Galactica
I changed the oil in my 76 A4 today in preparation for a 3000 mile trip I plan on doing in a week's time. When I dropped the oil filter I saw a significant amount of material like copper filings on the filter base. Is this likely bearing material?
I've been riding quite a bit. Haven't noticed any untoward noises ie. big end knock under load. She runs and sounds really good.
Should I be thinking of scrapping my trip? I've been planning it for over a year.
Maybe it was there before and I didn't notice it. The oil was changed last spring at the Kaw dealer ( the first one since at least 1988), and I did one change last fall.
I thought I would go for a good ride this weekend, then drain the oil and check for residue. The thinking being that any damage is already done and I would just be confirming a problem.
Any thoughts guys?
Ross
77KZ1000
76 KZ900
01 Jul 2010 20:40 #379578 by PLUMMEN
Replied by PLUMMEN on topic Copper filings on oil filter base.
put a few miles on it and dump the oil again
01 Jul 2010 22:00 #379583 by bountyhunter
Replied by bountyhunter on topic Copper filings on oil filter base.
The bearings are the only thing I know of that are bronze. Have you tried plugging in a gauge and checking the oil pressure? If you have good pressure at hot idle, it's probably OK.
02 Jul 2010 06:27 #379623 by otakar
Replied by otakar on topic Copper filings on oil filter base.
There is nothing that I can think of in the entire system that is made out of copper/brass/bronze. These bikes have very low oil pressure systems. Only around 3psi or so The Oil light would be red if the oil pressure fell even a little bit. I would check the clutch to see maybe it is grinding and those are discolored steel shavings.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • Motor Head
02 Jul 2010 06:51 #379625 by Motor Head
Replied by Motor Head on topic Copper filings on oil filter base.
Pretty easy to pull the pan and inspect, you may find that there is much more lurking there, or maybe not, but worth looking. Are the pieces magnetic? Have you tried to cut them with a razor blade to see the material from an different angle? Maybe a bearing is starting to wear, most main and rod bearings are copper base with a babbit coating. Once the coating wears it is time for the copper. The other style is a aluminum construction, not sure which # hardness, this is popular with Import car motors these days but an older Kaw?
02 Jul 2010 07:19 #379631 by otakar
This engine has needle bearings. This is why the oil pressure is so low. On plain bearings the oil pressure is much higher. I do agree however with the removal and inspection of the oil pan. As I stated before, there is nothing copper in this engine with the exception of the alternator stator.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • 9am53
  • homebrew, and some bbq
02 Jul 2010 07:20 #379632 by 9am53
Replied by 9am53 on topic Copper filings on oil filter base.
what about cam bearings?
  • Motor Head
02 Jul 2010 07:45 #379635 by Motor Head
How about the clutch basket, where it goes onto the shaft, does it have the Copper/ Bronze bushing?
02 Jul 2010 08:03 - 02 Jul 2010 08:11 #379636 by otakar
Cam bearings are babbitt / white metal and the clutch basket is supported by a very large ball bearing. The shavings from the cam bearings would be silver. The other bearing in the clutch is a needle bearing. If that was bad, he would know it. There would be extreme vibration and the clutch would rattle. But once again, all steel.
I think that pulling the oil pan for a better inspection would be a very good idea.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 02 Jul 2010 08:11 by otakar.
  • Motor Head
02 Jul 2010 08:15 #379638 by Motor Head
What about the cam chain Idler/ guide rollers? What type there?
02 Jul 2010 08:24 - 02 Jul 2010 08:24 #379639 by otakar
There is a little bit of bronze in those, but if there was that much in the oil he would know it. The cam chain would be rattling like mad and he would also have a large amount of black rubber particles to accompany the shavings because the roller would be wobbling and grinding itself away.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 02 Jul 2010 08:24 by otakar.
  • testarossa
02 Jul 2010 08:25 #379640 by testarossa
Replied by testarossa on topic Copper filings on oil filter base.
Those should be roller/needle bearings also. They are on my KZ1000A2.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
