Copper filings on oil filter base.
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- Motor Head
- Thank you received: 391
- Motor Head
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Motor Head
- otakar
Looking at the parts fiche I would be pulling the valve cover as well to Inspect.
Checking the cam chain guide and tensioner components would not be a bad idea. Unfortunately to check all of them correctly would also entail removing the head also. When was the last time the valve clearances were inspected?
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Galactica
- Thank you received: 2
These filings were very fine, and stuck to the filter base like a dense paste. They were in a moon sliver shape about 1/4" wide X 1 1/2 inch long. I should have taken a photo.
They sparkled a little like the sparkle you see in Never Seaze compund, but definitely copper coloured.
The oil pressure light has not gone on and the bike sounds and runs great. I'll see if the Kaw shop has a pan gasket and I'll pull the pan.
R
77KZ1000
76 KZ900
- Galactica
I strongly suspect big end bearing(s).
So much for the trip I've been planning for over a year. I was really looking forward to some solo time, and mountain riding.
Sometimes life just gets in the way. They say bad luck comes in 3s. The clutch on my 2006 Frontier started to slip a coupla weeks ago. Needs a new friction disc ($450) and dual mass fly wheel ($1000!!!!!) plus labour. After taxes will be well over $2600. Of course Nissan doesn't cover ANY clutch related problems under warranty after 3 years.
I'm just waiting for the other shoe to drop.
R
77KZ1000
76 KZ900
- porchev914
- Thank you received: 19
FRANKEN Z!
- Motor Head
This way if you need some parts you can get them ordered.
- Galactica
The valve clearances were checked At the Kaw shop a little over a year ago. I have no reason to suspect that they are not correct. Plugs all look good and all head pipes heat evenly. No unnatural noises or problems.
R
77KZ1000
76 KZ900
- Galactica
77KZ1000
76 KZ900
