- Thank you received: 391
Base Gasket STILL $%#@%!#@% leaking.
- Motor Head
Those dowels are there to make sure all of the top end engine parts are running true, piston to bore/ cam chain, etc.
- TerryK
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
- keith1
- Thank you received: 2
- nads.com
- Thank you received: 20
- bountyhunter
- Thank you received: 337
- beefsquasher
The solution was a combination of things:
The cylinder studs were not sealed at the bottom (i.e not blind holes), but were open to the crankcase. This was causing crankcase pressure to push out sealant around the studs. Used ARP Thread Sealant.
The new dowel pins were actually a bit tall, combined with accumulated gunk in the dowel holes in the block, caused the block to not tighten down enough. Cleaned dowel holes, trimmed down dowels on a lathe.
Used a thick, soft aluminum shim with Yamabond 4 on both sides (recommended by Redline Cycles). This also solved my pinging problem when the bike gets hot.
Torque head to 31 lb-ft. This is the FSM torque. I had been using the APE recommendation of 36-42 lb-ft for their heavy duty studs, but I noticed that the gasket was being crushed flat in the areas around the studs and actually lifting up in the spaces between.
I have no idea which one of these changes made it not leak but I am a very happy camper.
-Dave
1977 KZ1000 Mutt - 1075, Kenny Harmon Cams .400", RS34, Kerker, Dyna S
1997 Honda XR250R
1977 Yamaha XS360
1972 BMW R60/5
- 79MKII
- Love Them Kaws!
- Thank you received: 43
...Used a thick, soft aluminum shim with Yamabond 4 on both sides (recommended by Redline Cycles). This also solved my pinging problem when the bike gets hot. ...
Interesting...where does the shim go?
The Kaw List:
- mark1122
- Keep twisting it
- Thank you received: 109
i find this strange .
if all of the surfaces are true u should not get this?? unless the cases and block bent as u torqued??.
Just a note for u if it fails again.
i had to have my case top milled. it was not flat from the factory.
i use ape studs too. i torqued mine to 40 then 42 after a heat cycle, then 42 again after another cycle. i'm sure the odds of stopping a leak by re-torquing tighter are not as great as starting tighter and preventing the leak in the first place.
does this motor have higher compression and larger pistons??
if so u should seriously look at more crank case venting. poor venting is known to cause leaks.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- larrycavan
- Visitor
- TerryK
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
- Kawboy74
- Thank you received: 52
David
1974 Z1A As original as I could get it
'88 ZX750R braided lines, mostly original
KZ1000 project on the bench
Burlington,Ontario,Canada
- staniel
Why did they taper it in just to taper it back out to the threads? What purpose does that serve other than weakening it? I'm planning to replace it with a 12mm with no taper and threads all the way down.
1983 KZ750 L3 with 4-1 Kerker pipe and pods
1983 KZ750 L3 parts bike
