- Thank you received: 2098
77 KZ1000 Spark Plugs Question
If continue tapping (chasing) the buggered thread pattern from the top, will cut new threads entire length of hole, also through the original deeper threads. Maybe okay. Maybe not so okay.
Imo should consider using a reverse tap, which begins from the bottom deep end of the spark plug hole from inside the combustion chamber. This will re-tap the original threads on up through the buggered portion lying closer to the top.
Removal of the head is unnecessary.
Some folks apply grease to the tap and work one turn at the time, whereby the "shavings" are trapped in the grease, and the tap may be withdrawn, cleaned, re-greased, and repeat.
Btw, the small magnet may help remove particles that are attracted to the magnet. However, aluminum, stainless steel, and some other metals aren't attracted to a magnet, which would especially apply to aluminum shavings from re-tapping a spark plug hole.
Here's a pic of the reverse tap tool. Sometimes called a back tap.
- testarossa
- Thank you received: 82
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
- 1977kz1000
- Old Man Rock
- Thank you received: 225
Plugs... B8ES or something other?
Thread lengths the same as B8's....
Are you positive plugs aren't hitting valves or "holly shit" factor piston domes?
Under ignition plate, ignition advance unit shows TDC 2/3, if so rotate 17mm nut forward direction insuring pistons 2/3 not TDC... Plugs insert fully now?
This is a weird one no doubt...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- bountyhunter
- Thank you received: 337
Interesting. I thought the chasers would not "track" a cross thread pattern which is why they were useful. It's been 30 years since I saw one used so maybe not. The reverse thread cutter sounds like the plan to go with.Would suspect the beginning threads have been crossed and plug forceably turned in part way, which forcing buggered the threads from top of hole downward to some uncertain point.
- TerryK
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
- 1977kz1000
Heres how I used the thread chaser for anyone else who may be wondering. Lube it up with some PB buster or some WD40 to break up any nastiness that may be lingering inside the thread hole. Then lube up your tap/chaser. Go in slowly! The moment you feel tension building, start backing out and then go back in again. This is a long process and don't be surprised if it takes you a while. After you get it done, you'll notice that the threads look almost like brand new. (Make sure you also have lots of lube on the chaser - some shavings will stick to the liquid - and a metal brush to keep your tap/chaser clean when you go back in)
DON'T FORGET TO GET THE SHAVINGS OUT! When I got the threads done, I figured there would be shavings in the cylinder... so believe it or not I got a magnet and just fished it around in there and the shavings stuck to it which amazed me because I thought aluminum isn't magnetic. I actually think that the spark hole is some sort of composite...because curly shavings stuck to the magnet. Do this after every chase to keep up on it. Then I just kicked it a few times.
Plugs when all the way in. You'll get some lube in the cylinder head and that will just burn off. You'll also burn off anything at the top of the head where you put your plugs in. It will smoke for about a day...give it some good riding and it'll be okay.
I put iridiums in my bike and it's running great. Although last night the kickstand gave weigh and it toppled over. GOD DARN IT!
Thank you everyone for you help, and I hope my struggles will help out the next person. Remember, take it one step at a time and go in easy! The spark plugs should not be rough going in!!
- otakar
www.harborfreight.com/10mm-14mm-spark-pl...ad-chaser-66033.html
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
