77 KZ1000 Spark Plugs Question
26 Jun 2010 15:38 #378372 by 1977kz1000
77 KZ1000 Spark Plugs Question was created by 1977kz1000
I have a 1977 KZ1000. A week or so ago my girlfriend tried to move my bike, and ended up fouling out the plugs. Long story short, I put in new plugs, but didn't take note of the position of the plugs.
I put in the new plugs, plugs 1 and 4 went in all the way, but 2 and 3 (the inner plugs) go in easy for about 3/4 of the way and then it feels like they won't screw in any further. I spoke to a friend who suggested that I might be stripping them, but I took a look and the threads are fine on both the engine and the plugs.
My question is: is this normal, and do your bikes plugs on 2 and 3 go in easy/are flush with the engine?
The bike runs fine with them where they are, but I just wanted to be sure if it would be okay if I just tried my hardest to get them flush?
Let me know!
26 Jun 2010 16:13 #378390 by TerryK
Replied by TerryK on topic 77 KZ1000 Spark Plugs Question
Strange. They should all be the same....unless the holes are stripped (very possible) or maybe some dirt got on the threads. I would inspect those holes very closely. Try to spin the plugs in and then feel with your fingers if they are seated all the way.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
  • hocbj23
  • Visitor
26 Jun 2010 16:31 #378404 by hocbj23
Replied by hocbj23 on topic 77 KZ1000 Spark Plugs Question
Plug holes may have been stripped previously and somebody may have put a helicoil in there.Sometimes they work their way down and cause a funny feeling when u install new plugs.bj
26 Jun 2010 17:50 #378433 by 1977kz1000
Replied by 1977kz1000 on topic 77 KZ1000 Spark Plugs Question
They don't look stripped when I peek in the hole. It goes in really easy until about 3/4 of the way, then it feels as if there is some tension building. I stuck my fingers in there and I can feel the gap so I know it's not in there all the way. Is it possible that it's stripped far in there? If the plug can get in that far I find it hard to believe that it would have stripped!
Thanks for the input - what risk would I run just straining to get it in there? Or what risk would I run leaving them 3/4 of the way in?
26 Jun 2010 18:10 - 26 Jun 2010 18:25 #378443 by bountyhunter
Replied by bountyhunter on topic 77 KZ1000 Spark Plugs Question
Before you try to force anything: they sell a tool called a thread chaser that will run the threads out. It's like a cutter so it will clean garbage out of the threads and clean up any flaky threads that have been dinged or cross threaded.
www.sears.com/shc/s/p_10153_12605_009473...&ci_sku=00947321000P
Last edit: 26 Jun 2010 18:25 by bountyhunter.
26 Jun 2010 18:24 #378447 by bountyhunter
You could trash the threads out.
BIG RISK: if the spark plugs are not pulled down , the compression rings are not flush with the head. You are "holding compression" in the threads alone.
26 Jun 2010 18:30 #378448 by Old Man Rock
Replied by Old Man Rock on topic 77 KZ1000 Spark Plugs Question
Bounty... With that tool, head off or on?
Reasoning I ask, won't the cut material fall into the piston/combustion area... Probably small and insignificant but had to ask just the same....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
26 Jun 2010 21:27 - 26 Jun 2010 23:14 #378475 by bountyhunter
Good question, I have only seen them used head on. It's only to clear the threads that are already cut so the amount of material that would come loose should be very small. And it should be hard carbon and/or burned oil residue which would blow out OK.
Last edit: 26 Jun 2010 23:14 by bountyhunter.
26 Jun 2010 22:46 #378481 by wannaby
Replied by wannaby on topic 77 KZ1000 Spark Plugs Question
stick a vacume cleaner with a small tube on the end into the plug hole if your really worryd.
26 Jun 2010 23:12 #378483 by bountyhunter
You wouldn't believe what I "dropped" into a cylinder. The stupid spark plug on my wife's Saturn basically disintegrated and I had to take it out in pieces. When I got done, I realized a piece was missing: the metal rod that goes up through the insulator (the insulator had broken into pieces). There was also oil down there and when I took what was left of the plug base out, the metal piece fell in. I installed a good plug and started it and it was shaking like a paint shaker.... running on three cylinders.
There were not many options so I just revved it a while and it finally blew that piece out through the exhaust and it has run OK since. :blush:
27 Jun 2010 05:53 #378502 by Old Man Rock
Can't speak for everyone else but zoomed in, this tool is a large 14mm tap..... Thus in a stripped aluminum head, oh yeah there's going to be some crap falling into the chamber....
Downfall is the head gaskets aren't the cheapest @ $50 but neither is a blown/seized engine, metal shaving caught in valve lip etc.... Pull the head would be the way I'd go to accomplish...
But that's just me.... :blush: :laugh:
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
  • hocbj23
  • Visitor
27 Jun 2010 06:17 #378509 by hocbj23
available is a vinyl covered magnet about the size of a pecil eraser on a telescoping rod.If concerned about shavings,get one of those,put in plug hole wiggle around and retrieve all the shavings-metallic trash etc.bj
