77 KZ1000 Spark Plugs Question
- 1977kz1000
I put in the new plugs, plugs 1 and 4 went in all the way, but 2 and 3 (the inner plugs) go in easy for about 3/4 of the way and then it feels like they won't screw in any further. I spoke to a friend who suggested that I might be stripping them, but I took a look and the threads are fine on both the engine and the plugs.
My question is: is this normal, and do your bikes plugs on 2 and 3 go in easy/are flush with the engine?
The bike runs fine with them where they are, but I just wanted to be sure if it would be okay if I just tried my hardest to get them flush?
Let me know!
- TerryK
- Thank you received: 3
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
- hocbj23
- Visitor
- 1977kz1000
Thanks for the input - what risk would I run just straining to get it in there? Or what risk would I run leaving them 3/4 of the way in?
- bountyhunter
- Thank you received: 337
www.sears.com/shc/s/p_10153_12605_009473...&ci_sku=00947321000P
- bountyhunter
You could trash the threads out.what risk would I run just straining to get it in there?
1977kz1000 wrote:
BIG RISK: if the spark plugs are not pulled down , the compression rings are not flush with the head. You are "holding compression" in the threads alone.Or what risk would I run leaving them 3/4 of the way in?
- Old Man Rock
- Thank you received: 225
Reasoning I ask, won't the cut material fall into the piston/combustion area... Probably small and insignificant but had to ask just the same....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- bountyhunter
Good question, I have only seen them used head on. It's only to clear the threads that are already cut so the amount of material that would come loose should be very small. And it should be hard carbon and/or burned oil residue which would blow out OK.Bounty... With that tool, head off or on?
- wannaby
- bountyhunter
There were not many options so I just revved it a while and it finally blew that piece out through the exhaust and it has run OK since. :blush:
- Old Man Rock
Downfall is the head gaskets aren't the cheapest @ $50 but neither is a blown/seized engine, metal shaving caught in valve lip etc.... Pull the head would be the way I'd go to accomplish...
But that's just me.... :blush: :laugh:
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- hocbj23
- Visitor
