PAN SHRAPNEL!! ANYONE RECOGNISE????? PULL RING !
  • Motor Head
  • Topic Author
21 Jun 2010 15:48 - 22 Jun 2010 06:13 #377332 by Motor Head
Well I just dropped the pan on my 82 KZ1000 LTD, found something I don't recognize, and it almost looks like a pull tab from a can. Of course it is not, and it is much harder metal, Non magnetic, Looks bent and broken like it used to have 2 loops maybe? Its got me worried as I want to ride it on a 3000mi round trip.
Now it has 26000mi, and I've done the top end and cam chain, bike runs sweet and shifts perfect. The only noises are from the Starter, cranks up easy but has a growl. Pulled and checked it, lubed etc still the same. Also has what I would describe as a "DRY" sounding bearing in the transmission, more apparent in 4-5 gears, that's why I pulled the pan.
Last edit: 22 Jun 2010 06:13 by Motor Head. Reason: Update Title
  • testarossa
21 Jun 2010 15:52 #377334 by testarossa
Replied by testarossa on topic PAN SHRAPNEL!! ANYONE RECOGNISE?????
Could it be a old master link from a cam chain? Do you have a picture?
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • Motor Head
  • Topic Author
21 Jun 2010 15:58 - 21 Jun 2010 16:14 #377337 by Motor Head
Replied by Motor Head on topic PAN SHRAPNEL!! ANYONE RECOGNISE?????
Not Master Link, Working on Resizing so I can post a pic.
Last edit: 21 Jun 2010 16:14 by Motor Head.
  • Motor Head
  • Topic Author
21 Jun 2010 16:17 #377342 by Motor Head
AND
  • Motor Head
  • Topic Author
21 Jun 2010 16:18 - 21 Jun 2010 16:19 #377343 by Motor Head
AND
PICASA 3 EASY AS PIE TO RESIZE
Last edit: 21 Jun 2010 16:19 by Motor Head.
  • larrycavan
  • Visitor
21 Jun 2010 16:23 - 21 Jun 2010 16:29 #377344 by larrycavan
Replied by larrycavan on topic PAN SHRAPNEL!! ANYONE RECOGNISE?????
Sure does look like a tossed beer can tab :laugh:
Is it magnetic?
Can't think of anything that would look like that. On a J you can pull the clutch basket without splitting the cases. Might be worth your while to have a look there as well.
Here's a pic of crank and trans
Last edit: 21 Jun 2010 16:29 by larrycavan.
21 Jun 2010 16:29 #377345 by KZ250LTD
Replied by KZ250LTD on topic PAN SHRAPNEL!! ANYONE RECOGNISE?????
+1, maybe the PO liked to have a few sips while he worked? Doesn't look like anything recognizable from the engine to me though
Is it magnetic?
79 KZ1000ST
Past:
Many.
21 Jun 2010 16:33 #377347 by polkat
Replied by polkat on topic PAN SHRAPNEL!! ANYONE RECOGNISE?????
You said that it's non-magnetic, so that would almost certainly make it aluminum. So it's not a master link (which couldn't get into the pan anyway). Also looks vaguely like crushed tubing, or maybe a part of a shifter cog??? Does it shift well?
  • trianglelaguna
21 Jun 2010 16:39 - 21 Jun 2010 16:40 #377348 by trianglelaguna
Replied by trianglelaguna on topic PAN SHRAPNEL!! ANYONE RECOGNISE?????
+3
or an old tarp gusset/eye rivit...
is it magnetic..???great question
get an old coors/pabst/miller pop top and compare the crimps....kawasaki guys never drink budwieser so don't waste your time with them...or imports unless it's sapporo
good luck...this will require and update......
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Last edit: 21 Jun 2010 16:40 by trianglelaguna.
21 Jun 2010 16:50 #377353 by Bad Dad
Replied by Bad Dad on topic PAN SHRAPNEL!! ANYONE RECOGNISE?????
Well... good thing you got it out! Put her back together with fresh oil & filter and "call it good"!
Sounds like she's running sweet, "If it's not broke, don't fix it"!!!
76 KZ900LTD
82 GPz750R1
01 VULCAN 800A-CHOPPED
76 IRONHEAD-CHOPPED
77 RD 400 Cafe
  • Motor Head
  • Topic Author
21 Jun 2010 16:54 - 21 Jun 2010 17:06 #377355 by Motor Head
Not Magnetic, and as I said looks like a pull for a can, but it is not. Aluminum most likely. I've never had the trans apart on a J, but on many other bikes/ cars/ equipment, nothing like this. I suppose it could have gotten there by a Human Hand besides its engineer. I'll pull the clutch, and the stator and look around. Better safe than sorry, might just split it and search for any thing worn. As I said shifts fine runs good and just a growl from the starter when engaged that sounds abnormal, starter looks good inside with sort brushes, on my shopping list, and what I describe as a "DRY BEARING" sound from the trans.
Going to post up a couple or more pics in a bit.
Last edit: 21 Jun 2010 17:06 by Motor Head. Reason: PIC
  • riverroad
  • 1980 1000LTD B4
21 Jun 2010 17:01 #377356 by riverroad
Replied by riverroad on topic PAN SHRAPNEL!! ANYONE RECOGNISE?????
Maybe it's a pull tab from a can of oil additive.
