- Thank you received: 391
PAN SHRAPNEL!! ANYONE RECOGNISE????? PULL RING !
- Motor Head
Now it has 26000mi, and I've done the top end and cam chain, bike runs sweet and shifts perfect. The only noises are from the Starter, cranks up easy but has a growl. Pulled and checked it, lubed etc still the same. Also has what I would describe as a "DRY" sounding bearing in the transmission, more apparent in 4-5 gears, that's why I pulled the pan.
- testarossa
- Thank you received: 82
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
- Motor Head
- Motor Head
- Motor Head
- larrycavan
- Visitor
- KZ250LTD
- Thank you received: 16
+1, maybe the PO liked to have a few sips while he worked? Doesn't look like anything recognizable from the engine to me thoughSure does look like a tossed beer can tab :laugh:
Is it magnetic?
Motor Head wrote:
Non magnetic, Looks bent and broken like it used to have 2 loops maybe?
79 KZ1000ST
Past:
Many.
- polkat
- trianglelaguna
- Thank you received: 235
or an old tarp gusset/eye rivit...
is it magnetic..???great question
get an old coors/pabst/miller pop top and compare the crimps....kawasaki guys never drink budwieser so don't waste your time with them...or imports unless it's sapporo
good luck...this will require and update......
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- Bad Dad
Sounds like she's running sweet, "If it's not broke, don't fix it"!!!
76 KZ900LTD
82 GPz750R1
01 VULCAN 800A-CHOPPED
76 IRONHEAD-CHOPPED
77 RD 400 Cafe
- Motor Head
Going to post up a couple or more pics in a bit.
- riverroad
- 1980 1000LTD B4
- Thank you received: 7
