Milled head
- Tomolu5
Re: Milled head
17 Sep 2012 18:14
Sounds like a problem with your ignition, the coils are constantly supplied with +12v, and the ignition(or points) provide a ground when its time for spark.
Mine:
04 Honda rebel 250(wifes)
04 GSXR 750(bolt on galore)
98 CBR 600F3(filter, pipe, adjustable cam sprokets, dyno tune)
76 KZ900A (LTD gauge pods, crash bars, LTD(style)pipes, dyna coils and ignition,headwork and mild port cleanup by cavanaugh racing, K&N filter pods, heck I dunno.
- steell
Re: Milled head
17 Sep 2012 22:49
Make sure the ignition is off and measure the resistance between the two small wires on the coil. Should be 2-3 ohms.
Measure the resistance between the two spark plug wires on the same coil (remove plug caps).
Should be 17k-23k ohms.
If coil fails either test, replace it.
- SATSFYD
Re: Milled head
18 Sep 2012 11:26
When you say test the two wires are you talkinf about the - and + going into the coil?
- SATSFYD
Re: Milled head
18 Sep 2012 11:27Tomolu5 wrote: Sounds like a problem with your ignition, the coils are constantly supplied with +12v, and the ignition(or points) provide a ground when its time for spark.
I was thinking it was the a "bad" wire coming from the pick up...
- steell
Re: Milled head
18 Sep 2012 12:52 - 18 Sep 2012 12:53
Yes, the + and - wires, the only two wires on the coil except for the spark plug wires.
When the ignition switch is "ON" you should have 10-12 volts at both the + and - wires on the coil, when the motor is running the igniter grounds the coil to charge the it, then disconnects the ground to fire the coil and create spark at the plug.
Last edit: 18 Sep 2012 12:53 by steell.
- Tomolu5
Re: Milled head
18 Sep 2012 13:35
It could be a bad wire(on mine it will be either the black or the green, and I would test that first(cheapest), then go through the paces for testing the ignition pick-ups.
Mine:
- SATSFYD
Re: Milled head
18 Sep 2012 17:04steell wrote: Yes, the + and - wires, the only two wires on the coil except for the spark plug wires.
I asked you this because I already did this... 11. something as notes in an earlier post.
- Mullineaux
Re: Milled head
18 Sep 2012 17:41
If the ground wire to a coil isn't grounding check the CDI igniter (ignitor) module with a multi meter and make sure it's within spec. If it is check the pickup coils. Replacement aren't too expensive on eBay, or there's always the Dyna S option.
KZ650 ( '77 Engine, '78 frame, 80's ignition, MAC 4-2 exhaust, Pods, lowered [links])
1980 XS1100 full Vetter dresser
- SATSFYD
Re: Milled head
18 Jun 2013 13:19
So after a few (yes a few) months... I traced down the problem/s: The pick up coils went bad and had to replace them and the carbs needed cleaning even after I had drained all the fuel some was left here and there when I put her in stowage.
