new power for pens bike!!
  • testarossa
16 Sep 2010 19:51 #399220 by testarossa
Replied by testarossa on topic new power for pens bike!!
larrycavan wrote:
Here's a couple pics.
This is the head on the flownbench asty .400" lift without any valve job yet.
Runners are stock size at the boots. Throats are 88% with 91% bowls. Valves will be J 37 Intakes and 30 exhausts
Tested with an old CVK Keihin carb mounted up to as J intake boot.[900 ninja stock carb] This causes a 4mm mismatch at the port entyrance. Head pics more with no carb mounted.
I think I just learned something here.
Nice to see the shiny parts. That crank looks tasty.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • larrycavan
  • Visitor
16 Sep 2010 20:09 #399223 by larrycavan
Replied by larrycavan on topic new power for pens bike!!
another
16 Sep 2010 20:10 #399224 by irishwill
Replied by irishwill on topic new power for pens bike!!
glad somebody did ...cause its beyond me!
  • larrycavan
  • Visitor
16 Sep 2010 20:10 #399225 by larrycavan
  • larrycavan
  • Visitor
16 Sep 2010 20:11 #399226 by larrycavan
  • Motor Head
16 Sep 2010 20:16 #399230 by Motor Head
Replied by Motor Head on topic new power for pens bike!!
You do very beautiful work!
  • larrycavan
  • Visitor
16 Sep 2010 20:20 #399231 by larrycavan
Cams are Cam Motion Z1 grind. Keeps shim on top, short duration with 10mm net lift.
Carbs will be CRS29 Keihins
This will be a nice, quick street motor with excellent behavior and plenty of power to run around with.
If I was building a 1075 for myself, this motor has everything I would want myself.
  • larrycavan
  • Visitor
16 Sep 2010 20:24 #399232 by larrycavan
Thank you...
BTW.... those blades showed up. I have another custom set being made. That guy is an absolute pleasure to do business with. He's 60 so he knows his stuff and is very much an attention to detail and customer service driven. Can't say enough good about him....
Larry
  • Motor Head
16 Sep 2010 20:24 #399233 by Motor Head
Whats the Comp static ratio? And what Octane rating will be recommended, along with ignition timing total advance, or modified curve?
  • larrycavan
  • Visitor
16 Sep 2010 20:29 #399235 by larrycavan
They're 10.25 Wiseco pistons.
I'd run 93 octane and stock advance curve. Should be fine. I'm putting the cams on 108/110 centers.
  • Motor Head
16 Sep 2010 20:33 #399236 by Motor Head
I guess it will be up to the owner to get the gearing/ carbs etc set to his liking. You've built quite a few of these, what do they make, about X horses? I suppose that will be somewhat to his exhaust s well, but ball park?
  • larrycavan
  • Visitor
16 Sep 2010 20:43 #399238 by larrycavan
They're around 105 at the rear wheel. I could push for more peak but the goal is make broad power. That's why I like those Z1 grind cams.
I've had that same combo run 10.4 with a 200 lb. rider with a slick and a bar. Not bad for street motor.
