- Thank you received: 2
1075cc engine tech question
- keith1
Well, I am gonna recheck the timing first. Campbell is an expert on these things. He suggests marking the timing marks with chalk so they can be seen easier. He has told me where the marks should be at 2500 RPM. That is my next step. After that if the problem persists he suggests a compression test. Only after that if the problem still persists the next step is to check valve lash. Most of these things I had an idea that they could be it, BUT, it is his suggestion that we eliminate what he calls "the stupid things" first. So that is where I am right now.
good luck and let us know what you find....suggestions were made assuming you had ruled out the small stuff....but know what happens when one assumes...
- Z1000Lover
- Z1000Lover
- PLUMMEN
- Thank you received: 104
is he still building pipes?Well, Monty Campbell of California and the famed MaxiCarbs, and Maxi Dwell system, and also the best pipe money can buy for a Z1 called the Capmbell X-Pipe has given me a lot of useful tips. HIs suggestions are so far the best I have had anyone give me so far.
- Z1000Lover
- mark1122
- Keep twisting it
- Thank you received: 109
it would be simple to get the electric start going again. u can buy a used starter for about $20. then u just need the gear inside for another $10.
Why cant u ride it like that?
my 1200cc kz never idles bellow 1500 rpm.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- hocbj23
- Visitor
And "real men" then walk around with a limp after their mistimed Harley kicks the dogsh-- outta them.lol.bjI checked the condition of the springs and they seem fine and I have lubed them. One of my issues was that in timing it I did not know that Kawasaki placed two timing marks way out where the pivot point is for the advancers. Seems kind of weird to me to "hide" them like that. But that is where I realized my timing is supposed to be at 2500 RPM. Also the marks are hard to see, so I am marking them with chalk; that helps them to be more visible. I won't know until I get someone over to help me get her up on the stand. The stand I have is a hand made/welded job and it takes two people to manipulate it. Then you have to clamp the swing arm tubes to the rails on the stand. Otherwise the bike will fall off when you try and kick start it. And it has to be kickstarted because all components for the starter were removed years ago. But, and old Harley biker buddy of mine from years back always used to say that "real men kick start their bikes". I will know where to look after that.
- PLUMMEN
can you pm me his contact info?Yes, he is, and he still does carb work. I spoke to him yesterday on the phone. He will sell you a set of pipes for 579 plus shipping. He has the megaphones, and the canister style; either in chrome or black. If yo uwant to use the factory center stand you will need the canister types; the megaphones use the old centerstand mounts to hang from. He is going to bore my carbs out to 31mm and add a 5th fuel circuit to them. His work is guarunteed too.
- Z1000Lover
- Z1000Lover
- Z1000Lover
www.x-pipe.com/motorcycle.html
