1075cc engine tech question
19 May 2010 07:49 #369004 by Z1000Lover
1075cc engine tech question was created by Z1000Lover
I have a 77 Z1000. Here is a run down of what is in it. I need help from anyone who has ever built their engine like this:
1075cc, 10.25:1 compression, A P E .410 cams with 266 degree duration, mild street port, cams timed to I believe 110 degrees as per Greg Cope recommendation, Kerker 4-1 with no baffle,Dyna S ignition, Dyna coils.
I need to know what to expect as far as engine idle is concerned. As it is it will crank and warm up fine but as soon as you cut the choke off it dies unless it is idled up to 1500 RPM and above.
19 May 2010 07:51 #369006 by timebomb33
Replied by timebomb33 on topic 1075cc engine tech question
did you go thru the carbs at the same time as you built the engine because it sounds to me like you have plugged pilot circuits.
I THINK MY POWERBAND BROKE
19 May 2010 09:32 #369021 by Z1000Lover
Replied by Z1000Lover on topic 1075cc engine tech question
Yes, and two different sets of carbs have been tried, and the same results each time. However, so far I have used the set ups recommended by the so called pros, and that has been my results. What is being used is Mikuni 29mm smoothbores, with 120 mains, 17.5 pilots, 1.0 air screws.
I was mainly wondering if anyone had built their engine up like this before, and what settings they may have used.
I have some 35 pilots coming soon, and still have the old 25s. I also stil have the old .9 airscrews. I am thinking it is in the carburetion, but maybe someone who has built their engine like this before has more insight. I hate to sound like a novice, but I have never had an engine this modded up before. I also do not run the factory airbox, but I used K&N pods.
19 May 2010 09:43 #369022 by sramsey216
Replied by sramsey216 on topic 1075cc engine tech question
I had the same problem (carbs were right but wouldn't idle). I fixed my problem by retarding the timing.
Yours seems a little high but someone with a little more knowledge can chime in.
-Scott
1980 KZ1000 LTD
19 May 2010 16:54 #369084 by beefsquasher
Replied by beefsquasher on topic 1075cc engine tech question
I had the same problem on my bike which has avery similar setup to yours. Went away when I synced the carbs.
BTW, I have never gotten the hang of syncing the carbs on my KZ with vacuum guages. I simply bench-sync them with 4 ball bearings, get them to all fall through at the same time as I turn the idle adjuster in.
-Dave
1977 KZ1000 Mutt - 1075, Kenny Harmon Cams .400", RS34, Kerker, Dyna S
1997 Honda XR250R
1977 Yamaha XS360
1972 BMW R60/5
19 May 2010 16:55 #369086 by keith1
Replied by keith1 on topic 1075cc engine tech question
i had basically the same engine with smaller cams and had the same EXACT problem you have ....three diff sets of carbs , played with timing, different jets,etc , etc....drove me frackin nuts
my problem, and i suspect yours, was with the cam timing...to make a long story short, i was 28 pins apart , but i didnt set the mark for the exhaust right at the edge of the head...itwas a little high, so i was running them out of phase....tdc wasnt really tdc....i dont know if that makes sense.....the bike ran well down the road, but wouldnt idle below like 1600...any attempt to set it lower, and it just fell like a rock and died.....i would pull the cam cover and seriously take a look at the cam timing....hope this helps.....let us know how you make out......keith
19 May 2010 16:56 #369088 by beefsquasher
Also, make sure the advance unit isn't sticky and hanging up or the springs aren't sacked out. A wandering advance can cause all kinds of funny problems like this, but the bike will run down the road fine b/c at speed, the weights are all the way out and not changing the timing.
-Dave
1997 Honda XR250R
1977 Yamaha XS360
1972 BMW R60/5
19 May 2010 17:03 #369093 by Z1000Lover
So far that seems like about the only thing I can look at. The guy that built it kept no records, only said "it was right". I have always wondered about it. I may end up retiming the cams myself. I have the kit and the tools. This is all good info that helps me out. I always did wonder if maybe he had the cams timed too radically. Guess I need to get mu tools out. Dang it too. I have sunk so much money and time into this thing. Well, I love her any way.
19 May 2010 17:05 #369094 by keith1
29 smoothies with those jets and air screw should be just right.....i ran the same combo once i got cams straightened out and it was pretty spot on....bike ran and idled well.....
22 May 2010 16:46 #369887 by Z1000Lover
Well, Monty Campbell of California and the famed MaxiCarbs, and Maxi Dwell system, and also the best pipe money can buy for a Z1 called the Capmbell X-Pipe has given me a lot of useful tips. HIs suggestions are so far the best I have had anyone give me so far.
22 May 2010 16:54 #369889 by keith1
so where do you stand and whats the verdict?
22 May 2010 17:06 #369890 by Z1000Lover
Well, I am gonna recheck the timing first. Campbell is an expert on these things. He suggests marking the timing marks with chalk so they can be seen easier. He has told me where the marks should be at 2500 RPM. That is my next step. After that if the problem persists he suggests a compression test. Only after that if the problem still persists the next step is to check valve lash. Most of these things I had an idea that they could be it, BUT, it is his suggestion that we eliminate what he calls "the stupid things" first. So that is where I am right now.
