- Thank you received: 1
Curious about ticking noise
- MajDSaster
28 Apr 2010 18:26 #363992
by MajDSaster
Current Ride: 2005 Kawasaki Vulcan 750
4th Ride: 1981 Kz1000 LTD (2008 - Storage)
3rd Ride: Wife (1999 - 2005)
2nd Ride: 1982 Kz1000 LTD (1983 - 2004)
1st Ride: 1977 Yamaha SX-650 (1981 - 1983)
Replied by MajDSaster on topic Curious about ticking noise
My first Kz1000 had a tick that seemed to be from one of the valves on the #4 cylinder. My mechanic tried different shims but nothing seemed to work. Bike worked fine for the, almost twenty years, that I had it, so I just didn't worry about it.
- Thank you received: 2098
28 Apr 2010 18:30 #363997
by Patton
Replied by Patton on topic Curious about ticking noise
If not already done, a proper carb sync often significantly reduces cam chain noise.
- Polar_Bus
- Thank you received: 7
29 Apr 2010 09:28 #364117
by Polar_Bus
Bikes:
'84 GPz1100
'06 HD Fatboy
Replied by Polar_Bus on topic Curious about ticking noise
I don't intend to scare the crap out of you, but my "tick" (along with some blue smoking out the exhaust) after my GPz1100 sat for 16 years dormant, ended up costing me $1200 to fix. Long story short, my #1 exhaust valve siezed to the valve guide and caused all sorts of problems. Luckily I got hooked up with an awesome motorcycle performance machine shop called Carolina Cycle. The owner was well aware of this issue, knew exactly how and how much to fix and remachined my head with all new oversized exhaust valve guides for very reasonable money ($400).
Bikes:
'84 GPz1100
'06 HD Fatboy
- sft1662
29 Apr 2010 14:28 #364249
by sft1662
1978 KZ650 B2A
Replied by sft1662 on topic Curious about ticking noise
My kz650 has a fairly obnoxious ticking sound too. It didnt go away with adjusting the cam chain tensioner as per factory manual. Oh well... I think its probably valve clearances because I have yet to check them - could be exhaust leak (pretty sure I might have one, some rust on the pipe joint?), definitely need a vacuum sync. Bottom line, if its running fine dont stress too much about it - but dont put off the maintenance for too long either.
I've also read in several threads/ websites that these old Kawasaki bikes are pretty notorious for having obnoxious and strange noise-making (but good) engines...
1978 KZ650 B2A
- chrispysaki
30 Apr 2010 13:33 #364485
by chrispysaki
Replied by chrispysaki on topic Curious about ticking noise
Mine ticks, too. It's mostly before it's warmed up, then it mostly goes away. Sometimes at very low idle it's noticeable. Runs great otherwise, so I haven't taken the time to troubleshoot it yet.
- Old Man Rock
- Thank you received: 225
30 Apr 2010 20:27 #364601
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic Curious about ticking noise
If ticks when cold then quiets down when hot... Hmmm, let me think about that for a moment... EXHAUST LEAK!
When it get's hot, metal expands so sealing up the leak better...
What are the conditions of the exhaust gaskets?
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- KZ1000CSRman
04 May 2010 13:41 #365490
by KZ1000CSRman
'82 KZ1000 CSR
Replied by KZ1000CSRman on topic Curious about ticking noise
I've also read in several threads/ websites that these old Kawasaki bikes are pretty notorious for having obnoxious and strange noise-making (but good) engines...[/quote]
Yeah, I am not going to stress too much about. It seems to run just fine. Its just that, after reading all the stuff in the forums here, I just got a little paranoid with every
little thing.
little thing.
'82 KZ1000 CSR
- KZ1000CSRman
04 May 2010 13:44 #365494
by KZ1000CSRman
'82 KZ1000 CSR
What are the conditions of the exhaust gaskets?[/quote]
I do not know the condition of the gaskets. Sooner or later, I will check up on it, but for now, I hope it will not do any bad. Thanks for advice though.
'82 KZ1000 CSR
04 May 2010 13:58 #365498
by Patton
Might eventually notice some black goo oozing out around one of the exhaust clamps --- probably getting past a slightly leaking exhaust gasket.
And not hurting anything except maybe owner's pride.:lol:
- mduck
04 May 2010 17:19 #365538
by mduck
Brand new old
1982 Kz750
-mika-
Replied by mduck on topic Curious about ticking noise
Mine used to tick/knock when first started on a cold day and at low idle. Once it got warm it stopped completly. Yesterday the tickking go worse and dindt go away and it started pissing oil all around the seem of the head gasket..
i have to tear her down soon and see whats going on
Brand new old
1982 Kz750
-mika-
- KZ1000CSRman
05 May 2010 08:47 #365703
by KZ1000CSRman
'82 KZ1000 CSR
oh man,hope that wont happen to me...
'82 KZ1000 CSR
- Polar_Bus
05 May 2010 09:31 #365706
by Polar_Bus
Bikes:
'84 GPz1100
'06 HD Fatboy
I had the "cold exhaust tick" on my suzuki GS1100 too. The only fix, was to double up on the gaskets. Problem solved. Seems as though exhaust flange leaks are a bit more common on bikes with aftermarket exhausts. My GPz (OEM exhaust) seals up nicely with a single gasket.
Bikes:
'84 GPz1100
'06 HD Fatboy
