Curious about ticking noise
- KZ1000CSRman
'82 KZ1000 CSR
- havakaw
- Thank you received: 27
'80 KZ 750 LTD-H
'82 KZ 1100 A-2 Shafty (ex-bagger)
- TeK9iNe
- What did you do!?!
- Thank you received: 28
If its a fast constant rapping that stays the same no matter temps and its down low, it could be more serious.
You can use a length of hose as a stethoscope to pinpoint the location of the sound for a better diagnosis.
GL
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Thank you received: 2098
Usually not imminently serious, but is aggravating, and may start emitting some goo around the header clamps which migrates from there.
- bountyhunter
- Thank you received: 337
1) valve
2) low octane gas
3) exhaust leak
If an exhaust leak, it will get a lot louder as you open the throttle.
- KZ1000CSRman
The only other thing besides the ticking sound, when I ride, there is a misfire every now and then. Especially after I let off the throttle to slow down. I can hear a few popping noises. Could the ticking sound have something to do with the misfire?
'82 KZ1000 CSR
What I hear is not loud. I can hear it when I start up the bike, but after riding it, it seems to go away. The noise itself sounds like it is dry inside somewhere. Yes, it has oil in it and does not leak. I also used premium gasoline. The guy that I bought it from said he adjusted everything to spec, including all new hoses and all clamps tightened.
What I hear is not loud. I can hear it when I start up the bike, but after riding it, it seems to go away. --- Could be consistent with small exhaust leak, where heat expansion is helping prevent the leak. But may be a valve tapping (also consistent), or some other source causing the ticking sound.
The only other thing besides the ticking sound, when I ride, there is a misfire every now and then. Especially after I let off the throttle to slow down. I can hear a few popping noises. --- Exhaust popping on deceleration can sometimes be reduced or eliminated by enrichening the pilot circuits a tad, using the pilot mixture adjustment screws.
Could the ticking sound have something to do with the misfire? --- I don't see a connection between the ticking with either a cylinder misfire or exhaust popping.
If not already done, would assure valve clearances are within specs.
- hocbj23
- Visitor
- KZ1000CSRman
'82 KZ1000 CSR
- hocbj23
- Visitor
- Old Man Rock
- Thank you received: 225
1) Exhaust leak as mentioned... Now don't over torque these nuts.... Just synch them up a little... 10mm wrench or lightly with a socket/ratchet.
2) Perform the timing chain adjuster procedure in your manual...
If problem is still present, then stethoscope for exactly where the sound is being generated...
Example, could be some old RTV ball bouncing up in the valve cover... Could be a loose top idler assembly bolt and your hearing the vibration or tapping on the cover itself.
Just a few to come to mind... Is the sound lower or top end of the engine...
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- trianglelaguna
- Thank you received: 235
must be an old school kawi...
they tick...
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
