- Thank you received: 225
no oil flow on my kz900
- Old Man Rock
08 Apr 2010 05:32 - 08 Apr 2010 05:34 #359188
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic no oil flow on my kz900
Ok, easy way to confirm the sending units operation...
* Engine off, electrical off.
* Unbolt the sending unit from the engine case.
* If you look up inside the unit, you'll see the spring loaded/plunger for switch switch activation.
* Turn the key to on position but don't start the engine!
* Either lay the the sending unit on the engine case or use a jumper thus grounding the sending unit.
* With the spring/plunger not engaged due to no pressure, the spring/plunger will be fully extended thus grounded and your oil lamp should be ON.
* Press the spring up towards the switch spring/plunger thus simulating oil pressure, compressing the spring/plunger thus infinite continuity. The oil pressure lamp should turn off.
You can follow this and perform continuity measurements as well if your more comfortable not applying power.
Can't get any easier then that...
If sending unit/switch/lamp is working then you have low pressure/oil flow blockage or bearing wears occurring...
OMR
OEM Service Manual....
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 08 Apr 2010 05:34 by Old Man Rock.
- oneownerkz900
08 Apr 2010 10:31 #359225
by oneownerkz900
Replied by oneownerkz900 on topic no oil flow on my kz900
Thanks for all the responces to my post. The switch is working and no oil gets to the oil path so a pressure check would be of no help. I have heard that the oil pumps on kz900 were weak that the pumps on the 1000 and GPZ 1100 are better, so I think the oil pump is the problem .
- oneownerkz900
08 Apr 2010 10:37 #359227
by oneownerkz900
Thanks for your reply ,you are on target with the oil pump. The oil level is good and I hope to have a used oil pump and o-rings at home in the mail. I will close the side clearences up on the oil pump I have ordered by putting a thiner gasket on it of by sanding the housing down on a flat surface . Thanks for you help
- oneownerkz900
08 Apr 2010 10:42 #359229
by oneownerkz900
No sounds and the bike has 29000 miles on it
- oneownerkz900
08 Apr 2010 10:48 #359231
by oneownerkz900
Ran the bike about 15 sec. no oil came out of the unpluged hole
- School Teacher
08 Apr 2010 12:00 #359245
by School Teacher
1976 kz900 in parts but will be going some day soon
1980 kz1000G1
1976 kz900 parts bike
1979 kz1000 shaftie parts bike
1978 kz1000 33mm smoothies 1075 kit
Troutdale Oregon USA
Replied by School Teacher on topic no oil flow on my kz900
When you checked the gears did you put them back in?
1980 kz1000G1
