no oil flow on my kz900
  • oneownerkz900
  • Topic Author
07 Apr 2010 14:44 #359064 by oneownerkz900
no oil flow on my kz900 was created by oneownerkz900
This bike is my baby, owned her from the start. Stock motor only changes is the 4 into 2 pipes dyna ign.and seat.started having oil light problems last year. would take off fast and the light came on and would not go off. let it cool down and started it up and light went out. this happened one time last year but it seemed like the motor was running warm and slowed down at idle at stop lights. coils and ign cooked and replaced them this year now the bike oil light came on again after my first ride of the season and would not go off. pull the oil plug on the right side of the motor and started it up and no oil came out. checked the oil pump clearances and they were with in .004 of an inch. oil path is clean and not blockages iam lost as what to do help please.
  • Motor Head
07 Apr 2010 16:58 #359082 by Motor Head
Replied by Motor Head on topic no oil flow on my kz900
Best to remove the oil pressure switch and screw in a gauge to check oil pressure for real. You could have a defective switch or a wire shorting to ground, as this will turn on the light. Low oil pressure means its toast and will require a rebuild and new oil pump. What weight oil and brand are you running? This will effect oil pressure when hot if to thin.
07 Apr 2010 17:25 #359085 by keith1
Replied by keith1 on topic no oil flow on my kz900
the key here is the fact that he has pulled the plug on the side of the motor.....all electrical BS aside, it should be squirting oil......the only thing i can think of is a bad pump or a blockage....or no oil......was the pump replaced with a new oring installed flat side down?..was the pump primed?.....does it have the "gate mod"?.....these are very simple oiling systems that run at a low psi.....i would run it for about 10 seconds with the plug removed (not just cranking) and see what comes out ...after verifying oil level is full......good luck.....keith
07 Apr 2010 17:28 #359086 by Old Man Rock
Replied by Old Man Rock on topic no oil flow on my kz900
As mentioned... check pressure is in spec.... Oil pumps can be obtained off e-bay for $25 (what I paid for mine)...
Just in case....
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
07 Apr 2010 17:40 #359089 by BSKZ650
Replied by BSKZ650 on topic no oil flow on my kz900
maybe a bit more info,, how many miles are on the bike?
oil change, was the filter replaced and was it the right one, double check to see if something may be wrong there.
was it making any strange sounds when the light was on?
77 ltd1000, current rider
76 kz900, just waiting
07 Apr 2010 20:20 #359145 by School Teacher
Replied by School Teacher on topic no oil flow on my kz900
How long did you run it with the plug out?
1976 kz900 in parts but will be going some day soon
1980 kz1000G1
1976 kz900 parts bike
1979 kz1000 shaftie parts bike
1978 kz1000 33mm smoothies 1075 kit
Troutdale Oregon USA
08 Apr 2010 01:46 #359169 by Patton
Replied by Patton on topic no oil flow on my kz900
oneownerkz900 wrote:
...checked the oil pump clearances and they were with in .004 of an inch. oil path is clean....
Were the oil pump O-rings okay? :unsure:
www.z1enterprises.com/detail.aspx?ID=1562
www.schnitzracingstore.com/catalogs/cata...26712&showprevnext=1
Good Fortune! :)
08 Apr 2010 04:26 #359178 by BSKZ650
just had a thought this morning,, could the bypass valve be stuck?
08 Apr 2010 04:47 #359180 by Old Man Rock
Not sure about that Ron for as depicted in the technical screeny, the Bypass valve only bypasses the oil filter, the rest of the flow should be the same....
One thing I'd be confirming that oil indeed is reaching up top (cams)!
Could be that the oil sending unit is acting up as well...
Good luck...
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
08 Apr 2010 05:03 #359181 by Splandman
Replied by Splandman on topic no oil flow on my kz900
Im having a similar problem. Mine is only when I take off fast and then the light goes out after a few seconds. I assumed I needed the "gate mod". I experimented by running the bike up to 8-9k in 4th gear rolling into the throttle slowly and the light never once came on. Only in 1st and 2nd when I hammer the throttle.
Current Bikes
1980 KZ1000E
08 Apr 2010 05:16 #359184 by Old Man Rock
Just curious... oil levels correct, within spec?
If low, this could also cause the intermittent on/off lamp lighting during a hard twist and such....
Just a thought...
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
08 Apr 2010 05:31 #359187 by Splandman
I have been checking the oil a lot because I've been paranoid about it. My bike does smoke some on start up and has a small leak around the shifter. A few drops after a ride. I've been hesitant to fix much because I have plans to tear the whole engine down soon. I don;t believe I've ever let the oil level get out of spec though.
Current Bikes
1980 KZ1000E
