no oil flow on my kz900
- oneownerkz900
- Motor Head
- Thank you received: 391
- keith1
- Thank you received: 2
- Old Man Rock
- Thank you received: 225
Just in case....
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- BSKZ650
- Thank you received: 14
oil change, was the filter replaced and was it the right one, double check to see if something may be wrong there.
was it making any strange sounds when the light was on?
77 ltd1000, current rider
76 kz900, just waiting
- School Teacher
1976 kz900 in parts but will be going some day soon
1980 kz1000G1
1976 kz900 parts bike
1979 kz1000 shaftie parts bike
1978 kz1000 33mm smoothies 1075 kit
Troutdale Oregon USA
- Thank you received: 2098
...checked the oil pump clearances and they were with in .004 of an inch. oil path is clean....
Were the oil pump O-rings okay?
www.z1enterprises.com/detail.aspx?ID=1562
www.schnitzracingstore.com/catalogs/cata...26712&showprevnext=1
- BSKZ650
- Old Man Rock
One thing I'd be confirming that oil indeed is reaching up top (cams)!
Could be that the oil sending unit is acting up as well...
Good luck...
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Splandman
Current Bikes
1980 KZ1000E
- Old Man Rock
If low, this could also cause the intermittent on/off lamp lighting during a hard twist and such....
Just a thought...
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Splandman
Current Bikes
1980 KZ1000E
