- Thank you received: 2
A little more progress. W/pics
- keith1
- will61310
- Thank you received: 6
VERY nice bike!!!Thanks for all the compliments! The bodywork was painted by the previous owner. I did all the polishing. I also painted the wheels, brake components, and most everything else that is black.
I just got back from my first ride. She's way lean on the midrange. It idles good and blipping the throttle is crisp. Cruising down the highway it surges and is obviously starving for fuel. If I reach down and pull the choke on it's like flicking a switch. It comes alive. I'm running VM28's with 20 pilots and 120 mains. The needles are non-adjustable. I have one set of shims for the needles. Will this be enough? Can I use two shims if needed? I also have a set of 122.5 mains. Should I put them in yet, or try the shims first?
OMR, I'm taking Larry's advice as the gospel. I did one heat cycle and retorqued the head. After 50 miles I will do it again and change the oil and filter. I have the valves set at max clearance.
...1980 LTD 1000...
- nads.com
- Thank you received: 20
Try a 132 jet. Even if you change needle height, with a 122 main it will still be lean at wide open throttle. It sounds crispy because its lean, but that's no good for power. Having to choke it tells you that. If you want beastly power go bigger on the main. All your problems will go away. Be replaced by a smile.Thanks for all the compliments! The bodywork was painted by the previous owner. I did all the polishing. I also painted the wheels, brake components, and most everything else that is black.
- Bad Dad
I'd like to see the rear end, and what you've done with the tail light.
76 KZ900LTD
82 GPz750R1
01 VULCAN 800A-CHOPPED
76 IRONHEAD-CHOPPED
77 RD 400 Cafe
- Splandman
Sweet... need more pic's!
I'd like to see the rear end, and what you've done with the tail.
I said the exact same thing to my wife yesterday.
Current Bikes
1980 KZ1000E
- fordtruck
- fordtruck
'77 KZ1000-MTC 1075 kit. Stage 1 port
- larrycavan
- Visitor
I have a set of VM26's with adjustable needles. Will those work? I know there are different taper needles, so I'm not sure if I should just shim these or swap to the 26's needles.
YES! Use the needles from the 26mm carbs. They'll be fine. Put the clip on the 4th groove from the top to start and work from there.
BEAUTIFUL BIKE
Good combo is 0-6 needle jets or o-4 with 5dl31 needles.
- larrycavan
- Visitor
:laugh: My mind tends to work that way too....
- Old Man Rock
- Thank you received: 225
What... you guys think it's your birthday? :laugh:
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- Bad Dad
76 KZ900LTD
82 GPz750R1
76 IRONHEAD-CHOPPED
77 RD 400 Cafe
- fordtruck
