- Thank you received: 6
A little more progress. W/pics
- fordtruck
'77 KZ1000-MTC 1075 kit. Stage 1 port
- moneypit
- Thank you received: 35
2-76 kz900
St Paul MN
- 9am53
- homebrew, and some bbq
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
- Bad Dad
I still have a couple of things that I need to address before I can ride it. The little breather filter I bought won't work because it hits on the air pods. I also need to secure the side covers so they don't blow off.
Hey, you can still use that breather... just use a short lenght of hose, and tuck it up behind those side covers somewhere!!!
Bike's looking good, and just in time for Spring!
76 KZ900LTD
82 GPz750R1
01 VULCAN 800A-CHOPPED
76 IRONHEAD-CHOPPED
77 RD 400 Cafe
- keith1
- Thank you received: 2
I love the paint! looks sick
me too......cool combo
- Tony
- Thank you received: 13
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- Old Man Rock
- Thank you received: 225
Keep to the details in following the advise Larry provided (break in, torquing, ring seating operations, oil change and valve clearance checks etc...) and you'll have no regrets and should not have any issues...
OMR
Almost forgot... Where's our AVI clip of the start up?
This is a must, we demand it damn it!.... :laugh:
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- JR
- Thank you received: 448
More pics please
- fordtruck
I just got back from my first ride. She's way lean on the midrange. It idles good and blipping the throttle is crisp. Cruising down the highway it surges and is obviously starving for fuel. If I reach down and pull the choke on it's like flicking a switch. It comes alive. I'm running VM28's with 20 pilots and 120 mains. The needles are non-adjustable. I have one set of shims for the needles. Will this be enough? Can I use two shims if needed? I also have a set of 122.5 mains. Should I put them in yet, or try the shims first?
OMR, I'm taking Larry's advice as the gospel. I did one heat cycle and retorqued the head. After 50 miles I will do it again and change the oil and filter. I have the valves set at max clearance.
- keith1
Thanks for all the compliments! The bodywork was painted by the previous owner. I did all the polishing. I also painted the wheels, brake components, and most everything else that is black.
i would think 20/120 is the place to be....if you cant get some adj needles, try one set of shims.....you are 95%
there.....sounds like a little fine tuning(check your timing) and you will have a dependable rocket.....sweet!!!!
- fordtruck
