- Thank you received: 337
Lots of smoke
- bountyhunter
I can guarantee that a bad seal will NOT cause severe smoking as shown in the video. When I rebuilt my 750, it had low compression in one cylinder due to valves and one of the seals in that cylinder was torn to shreds and had no "top" anymore. I had no noticable smoking but it did let oil leak down and foul the plug when I shut it off.
- polkat
- Thank you received: 1
You didn't answer if the cylinders had been deglazed. Any rings will have a hard time seating to glazed cylinders.
- TeK9iNe
- What did you do!?!
- Thank you received: 28
Or no valve seal at all?
GL.
MAYBE head gasket leak, right in the middle where the rubber gasket is supposed to go... around cam chain.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- KZ1100 Bully
On the other hand, I recently replaced some valve seals (probably original!) that were so old and hard that they had to be literally chisled off! Plain rubber seals can be like that if they get real old.
I did deglaze the cylinders.
kzrider.com/index.php?option=com_kunena&...d=2&id=340868#340868
1983 Kawasaki KZ1100 Spectre D2
- KZ1100 Bully
Yeah it just flat out looks like a @#$%ed up ring... oil control ring...
GL.
I ordered a new gasket kit from Z1. I think it might be that middle rubber gasket around the cam chain. It looks like it might not have been seated right. That is why it was leaking in cylinder 2 and 3, right beside the rubber gasket. Going to replace the valve seals too, with the right tool it does not look that hard.
Your good TeK9iNe
Thanks guys
