- Thank you received: 3
Lots of smoke
- 9am53
- homebrew, and some bbq
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
- KZ1100 Bully
1983 Kawasaki KZ1100 Spectre D2
- 9am53
'84 GPz900r
'71 CB350
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- KZ1100 Bully
I read some were on here that you paid $50 for the tool?
- KZ1100 Bully
I rebuilt my engine last year with all new pistons rings seals and all. I just broke 800Mi on the engine today and after smoking to the point of burning over a quart of oil in 500Mi it is just now going away. The engine is braking in and the rings are starting to seat. That is 700Mi I suspect that it will be another 300Mi before it all gos away.
Wow, that's a lot of miles. Maybe I jumped the gun a little. Well after I put it back together I will let it smoke for 800 miles.
Was yours smoking as bad as mine?
- 9am53
'84 GPz900r
'71 CB350
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- KZ1100 Bully
if the ring end gaps and the finish on the cylinders are correct then it shouldn't smoke or at least be visable valve seals if they are bad will usally only cause the engine to smoke on start up i'd be looking at the ring directon make sure they are right side up.if they aren't it will smoke like a pig.
Ok,all the rings look right 2 and 3 pistons are the same as 1 and 4 which did not leak.
- Jack
- Thank you received: 7
Never had any problems with valve guide seals as far as getting them on/off. Use a small pick to lift them off,it doesn't matter if you rip them .The new ones will slide right on the tip of the guide. I've used other seals over the years- lots of import cars have 7mm. valve stems.I know older Honda Civic seals will work.
Good luck with your problems.
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
- TeK9iNe
- What did you do!?!
- Thank you received: 28
+1
Check it out.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- KZ1100 Bully
www.babbittsonline.com/pages/catalogs/vi...ion-valve-seals.aspx
