Lots of smoke
- KZ1100 Bully
1983 Kawasaki KZ1100 Spectre D2
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- BSKZ650
- Thank you received: 14
77 ltd1000, current rider
76 kz900, just waiting
- KZ1100 Bully
- bountyhunter
- Thank you received: 337
- BSKZ650
I went around the block 3km. Pretty sure the rings went in the right way.
how far is that in real miles ??..lol
ok, was it smoking like that after you installed the rings and rode it for how ever far?, next are you sure you havent over filled it with oil.
and last, would be to run a compression check to see where it stands
- KZ1100 Bully
Real miles about 2, just way to much smoke to keep going.
- TeK9iNe
- What did you do!?!
- Thank you received: 28
Check compression.
Rebuild.
GL.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Sandy
- Fly High,Tony
- Thank you received: 13
Did you install new ones when you had the head off?
1977 KZ1000 A-1
- KZ1100 Bully
Dried up valve-guide seals?...or even a broken one maybe.
I did not replace the seals. The more stuff I try and fix I break something else taking it apart or putting it back together. Looks like I will try to replace seals this time sense I will have it all apart again. Getting to the seals seems to be tricky.
- BSKZ650
just trying to get a better idea of what is wrong, could even be the head gasket.
just sayin
- KZ1100 Bully
