Have spark, Have gas, Carburetors rebuilt, NO RUN!
- Striker
What is the process of adjusting them? I just seated them gently in there after I cleaned them.where are the pilots adjusted to?
- roy-b-boy-b
- Thank you received: 103
Start at 1 1/2 turns out from lightly seated. Roy
- Striker
oh yeah I have those adjusted, I thought he was talking about adjusting the pilot jets themselves. heh. I found a couple different specifications for adjusting the idle mixture screws they both say start 2 full turns out from lightly seated, but from there one says +/- 1/4 turn and another says +/- 1/2 turn. Even if I'm running rich or lean it should still run. thanks though Roy.That would be No. 1 on the diagram.
- Striker
- Thank you received: 2098
...How much choke should I put on when starting, and how much gas should I give it?
With cold engine, choke full on, don't touch throttle (leave it completely closed), tranny in neutral, kill switch in RUN position, push starter button.
Did I mention DON'T touch the throttle? :laugh:
- PLUMMEN
- Thank you received: 104
- Striker
- timebomb33
I THINK MY POWERBAND BROKE
- Striker
please forgive my misuse of terminology I don't know any better yet. It's a bit different from chevys lol
- Striker
I've seen some things about testing the slides with compressed air, do I blow the air in the main jet with the spring off, take the jet out and blow?
- keith1
Click here for new vacuum caps (plugs) available from Z1E > Vac plugs from Z1E
