Have spark, Have gas, Carburetors rebuilt, NO RUN!
- Striker
My brother changed the oil and took the carbs apart, put them back together, put them on the bike and nothing couldn't even get the thing to fart. So I figure he did something wrong and rebuilt them myself, cleaned heavy deposits of grime out of every bowl, every jet, and the float needles, resync'd the valves on the Mikuni carbs, put them on myself and it still wouldnt run. Frankly I'm out of ideas as to why it won't run now. The only thing I think is weird is that when I'm turning the bike over and put my hand over the open end of any of the carbs I feel it suck my hand in then blow air back out of the carb.
I am new to working on motorcycles, so I need to know how much gas to give it, how much choke, and if there's anything else that I need to do to get it to start up. Thank you.
- Kawickrice
- Thank you received: 18
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
- Striker
- keith1
- Thank you received: 2
- Kawickrice
i m gonna go out on a limb and say those carbs need cleaned again....i would put an inline filter in also...the fact you had it running once, but now it doesnt, leads me to think there is a bit of dislodged crap in those carbs...got any pics of the carbs? the part that you redid carbs and had to get rid of heavy deposits means clean em again...4 cans carb clean,a wire carb orrifice cleaning tool and some compressed air...and when you think they are clean, do em again.....make sure you have eye protection....good luck
X2 It took me a couple of times on my 900 and four times on my 650. I can take the carbs apart blindfolded. Are the needle valves stuck how about float level. Dont take offense at redoing the carbs trhis is the nature of the beast.
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- Striker
- 2006hhr
- sbc1320
- Thank you received: 38
1980 KZ1000 LTD-B4(MK II engine) - Progressive suspension, MTC pistons, Dynojet Stage III, all wear items replaced, WFO paint scheme(1978), etc..
Past bikes- 2 1976 Kz900's, 5 1975-76 Honda CB750's, Honda 500 -4, Honda 250, Honda 125, Honda 100, Suzuki RM 250, Honda XL350, Kawasaki KLR 650, etc..
- PLUMMEN
- Thank you received: 104
- Thank you received: 2098
Float needles move freely and the floats themselves are set at 23mm
The physical measurement setting of float levels is notoriously inaccurate. Should perform clear tube test to verify actual fuel level inside float bowls.
Here's a method for cleaning the pilot circuit.
[Click on image to enlarge view.]
- 2006hhr
- Striker
It's a good possibility that that #6 orifice if it was clogged is still clogged, even though I blew out every passage with compressed air I didn't stop to think how many of them are interconnected and didn't block any off with my fingers. I will pull the carbs tomorrow and repeat the process. What is the clear tube test?Striker wrote:
