Silly Sprocket Question...
14 Mar 2010 15:13 - 14 Mar 2010 15:16 #353384 by jayw704
Silly Sprocket Question... was created by jayw704
So I only rode my KZ stock about 2 miles and never went above 35 because the brakes didnt work on the way (fun ride let me tell ya) any way I have done a ton of mods since then and I changed the drive to a 535 from a 630 and went to a 17T front and 39T rear sprockets. Heres the question at about 55 mph I am running about 3500 rpm. Is this normal high or low? It feels awful high to me but before I go lowering the rear and raising the front I thought I would get some feed back...
1978 KZ1000
Go Loud and go fast or dont go at all!!!
Last edit: 14 Mar 2010 15:16 by jayw704.
14 Mar 2010 15:15 #353385 by MFolks
Replied by MFolks on topic Silly Sprocket Question...
I've used www.gearingcommander.com when I did my sprocket gearing changes.
14 Mar 2010 15:49 #353393 by jayw704
Replied by jayw704 on topic Silly Sprocket Question...
That site is outstanding I wish I would have known about that years ago thank you so much!
1978 KZ1000
14 Mar 2010 22:00 #353550 by davel
Replied by davel on topic Silly Sprocket Question...
Great link. Thanks!
15 Mar 2010 18:35 #353733 by dragnkaw1428
Replied by dragnkaw1428 on topic Silly Sprocket Question...
Hey what front end are you using? Forks, triple trees ect.
Andy
  • WABBMW
  • Let The Good Times Roll !
15 Mar 2010 19:33 #353741 by WABBMW
Replied by WABBMW on topic Silly Sprocket Question...
Your sprockets give a ratio of: 39 / 17 = 2.294
I have experimented with different gearing on my 650, and found that 2.357 (33 / 14) is about as high as I can go without laboring the engine at 70 + MPH. That is with a 140/90 x 16" rear tire. Mine does 4,220. at a true 55 MPH, verified with a GPS.
I would think that at a true 55 MPH you would be turning about 4,350 RPM. The higher RPM is due to the smaller diameter of your rear tire as opposed to mine. I guessed that it is a 180/55 x 17.
If you have a 1000 cc engine, you might be able to go a little higher - If you are only interested in highway cruising, but it would not be worth changing sprockets. So in summary, I think you are geared as high as practical right now. If you want acceleration, then go smaller on the front and or larger on the rear.
Bill Baker
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
1977 Honda Supersport 750 four (sold)
1984 Honda Nighthawk 650 (sold)
15 Mar 2010 20:33 #353755 by dragnkaw1428
Hey what front end are you using? Forks, triple trees etc.:)
Andy
16 Mar 2010 07:47 #353815 by jayw704
Front end, triple tree, front and rear brakes, wheels, rear sets, clip-ons, levers and fluid reservoirs a all from a zx7r 91-95 rear wheel and brake took some modification but the with a steering head bearing change the steering bolt and triple tree bolted right on!
1978 KZ1000
16 Mar 2010 20:55 #353944 by dragnkaw1428
I like it! Ive been wanting to do some changes like that to my 77 1000 now I know what direction to start in. What steering bearings did you have to use? Do by some strange chance have the part numbers of the bearings?
Andy
17 Mar 2010 06:27 #353993 by zed1015
Replied by zed1015 on topic Silly Sprocket Question...
Hi.I'm running two z1000,s (both 1075 wiseco) with 17" zxr wheels. First one (z1r) is spot on running 17-33 gearing with 630 pitch and the other (Drouin) runs 18-40 with 530 pitch but could do with going to 19t on the front.
17 Mar 2010 09:48 #354031 by jayw704
Those are both some pretty sweet bikes you have there!!! What are the big contraptions on the side on one it looks like fuel injection? and on the other a hyd. shifter? Please do tell...
1978 KZ1000
17 Mar 2010 12:11 #354048 by bountyhunter
Replied by bountyhunter on topic Silly Sprocket Question...
Those look like they have a belt driven supercharge setup?
