Checking valve clearances with the head off?
- staniel
Re: Checking valve clearances with the head off?
10 Sep 2010 14:28
bountyhunter wrote:
I've been having this problem. Which is the right way to do it, then? With the chain tensioner on or off? A difference of .002" is pretty significant...polkat wrote:Does on mine, I have two shims that will change about .002 by releasing chain tension. I checked cam journal clearance and they are in spec.bountyhunter, let me see if I follow you. The clearance between the cam bearing journals and the bearing area is compressed downward by the chain tension, slightly changing the readings?
1983 KZ750 L3 with 4-1 Kerker pipe and pods
1983 KZ750 L3 parts bike
- bountyhunter
10 Sep 2010 14:37
staniel wrote:
I do the check with the chain slack pulled tight because that's the way it runs.bountyhunter wrote:I've been having this problem. Which is the right way to do it, then? With the chain tensioner on or off? A difference of .002" is pretty significant...polkat wrote:Does on mine, I have two shims that will change about .002 by releasing chain tension. I checked cam journal clearance and they are in spec.bountyhunter, let me see if I follow you. The clearance between the cam bearing journals and the bearing area is compressed downward by the chain tension, slightly changing the readings?
- bountyhunter
10 Sep 2010 14:39
fast_johnny wrote:
Interesting. I have noticed the spring pressure from the other side will lift the cam in the journals and affect the clearance a bit.I remember a shop in San Francisco, KC Engineering I think, where the owner was a KZ nut and he did a great job of bench shimming. He used an old KZ cam that was cut in half so he could bolt it in and check clearances without having to compress the valve springs on the open valves. I am about to do the same with the old cams that came out of my KZ as I won't be needing them anymore...
- larrycavan
10 Sep 2010 17:22
bountyhunter wrote:
Yes it can but it's not enough to matter. Lobe directly away on all valves works fine.
fast_johnny wrote:Interesting. I have noticed the spring pressure from the other side will lift the cam in the journals and affect the clearance a bit.I remember a shop in San Francisco, KC Engineering I think, where the owner was a KZ nut and he did a great job of bench shimming. He used an old KZ cam that was cut in half so he could bolt it in and check clearances without having to compress the valve springs on the open valves. I am about to do the same with the old cams that came out of my KZ as I won't be needing them anymore...
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
10 Sep 2010 21:31
I find the easiest way to rotate the cam is to mount a cam sprocket bolt in the cam and use a 10 mm wrench.
Just a note-
Always becareful with cam bolts. The torque is like #10.
So treat them with respect.
Just a note-
