- Thank you received: 1
Checking valve clearances with the head off?
- polkat
And should the noses of the lobes be 180 degrees away from the buckets when doing measurements?
Finally, is there a problem with swapping the shims around to bring clearances closer to stock? Thanks!
- Jack
- Thank you received: 7
Yes. Remember ONE cam at a time
Yes.
No problem.Cuts down on $$ shim inventory required.
If I can do it you can. Get a good manual, good luck.
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
- testarossa
- Thank you received: 82
As for swapping the shims...Swap away! The one time you won't get in trouble for swapping!:laugh:
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
- TeK9iNe
- What did you do!?!
- Thank you received: 28
Place a piece of towel down on the front or rear edge of the head, then you can wedge the driver in the cam gear and pry the cam gear upward a notch at a time.
Towel preventing damage to gasket surface of course.
GL
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- gane
[img][/img] 1977 KZ1000A1
- wrangler615
my .02
83 Kaw KZ750F1 - massive money pit
82 Zuki GS1100G - my daily driver, possible sacrilege I know
- bountyhunter
- Thank you received: 337
- polkat
My manual says that cam to bearing clearance should be about .19mm, half of which should be about .095mm clearance all around the cam when it is spinning in a bed of oil, which will, of course, hydroplane it off the bearing surfaces.
So, if I torque the cams in and then push down on it while taking the readings, seems I should be able to get pretty close. Even if the cam did shift downward from chain tension, which I wouldn't have with the head uninstalled, seems that I'd get ever so slightly more clearance then wanted, which is better then slightly less.
- OnkelB
- Thank you received: 80
As shown in the pic I also like to set the head on a couple of wooden blocks to raise it from the workbench - as you rotate the cam the valves will poke out beneath the head, if the head is flat on the workbench you risk bending a valve (might not happen, but better safe than sorry).
I find the easiest way to rotate the cam is to mount a cam sprocket bolt in the cam and use a 10 mm wrench.
77 KZ 650 B1, 82 GPz 1100 B2.
- Tyler
- Thank you received: 92
bountyhunter, let me see if I follow you. The clearance between the cam bearing journals and the bearing area is compressed downward by the chain tension, slightly changing the readings?
I have bench shimmed a head on my 650. I checked it after I installed it and ran the engine for for a short ride down the street and found the identical clearences as I did on the bench. I wouldn't worry too much about dynamic oil film or can chain force, you will be just fine shiming it properly off the engine. sincew I had ground the valves and setas I set the clearences up near the top end and tried to get them all within a thousandth. That gives me some room as the valves fin thier new home in the seats.
Just my 2 cents.
"74 Yamaha DT 400 Enduro
- bountyhunter
Does on mine, I have two shims that will change about .002 by releasing chain tension. I checked cam journal clearance and they are in spec.bountyhunter, let me see if I follow you. The clearance between the cam bearing journals and the bearing area is compressed downward by the chain tension, slightly changing the readings?
polkat wrote:
I think you want spec clearance with the thing installed and torqued down, and chain pulling down the cam which will close down the clearance a bit compared to "no chain" reading.So, if I torque the cams in and then push down on it while taking the readings, seems I should be able to get pretty close. Even if the cam did shift downward from chain tension, which I wouldn't have with the head uninstalled, seems that I'd get ever so slightly more clearance then wanted, which is better then slightly less.
- fast_johnny
1977 KZ1000A1 1075cc, Kerker, Cavanaugh Head, RS34s
1995 KZ1000P
