- Thank you received: 1
Scraping old gasket material sucks!
- Becker
- The Doctor Will Rise Again
04 Feb 2010 14:55 #346470
by Becker
I have one of these and as far as aluminum cases go it is irreplaceable. For castiron flat gasket scrapers work well but for this aluminum stuff the goodson is the only tool I'll use. It cuts gasket scraping time down alot. Just make sure that you don't put to much pressure on the ends of it or it will cut into the aluminum. It's very very sharp.
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
Replied by Becker on topic Scraping old gasket material sucks!
Goodson Tool www.goodson.com sells a 'super scraper'. This square-cut, hard-edged scraper is the best I've found for removing old gasket material.
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
- Visayanrider
04 Feb 2010 21:44 - 05 Feb 2010 00:19 #346551
by Visayanrider
Replied by Visayanrider on topic Scraping old gasket material sucks!
Hi everyone, my first post here. I was just cleaning the gasket surface of the headcover for my 1981 kz1100. It wasn't bad to start with but after trying a razor blade, I was dissapointed at how easy the blade would scrape off the soft aluminum. I took out a diamond hone and with a little solvent, just took everything off easy, it took maybe 10 minutes. Plus it helps flatten the surface. I think sandpaper on a glass plate would work but make sure to clean up the abrasive. Oh, BTW, my handle at KMF is "chocohills" just to let you know that I'm really not smart at all...:silly:
Last edit: 05 Feb 2010 00:19 by Visayanrider.
- APE Jay
- Banned
- Thank you received: 58
05 Feb 2010 20:53 #346771
by APE Jay
Replied by APE Jay on topic Scraping old gasket material sucks!
We use a wood chisel with a finely honed edge.
- bountyhunter
- Thank you received: 337
05 Feb 2010 20:57 #346773
by bountyhunter
Replied by bountyhunter on topic Scraping old gasket material sucks!
The secret is to always keep the blade's edge at right angle to the surface being scraped so it can't gouge or dig in.
