- Thank you received: 6
Scraping old gasket material sucks!
- fordtruck
I also ordered a new cam chain and rollers from Z1E. Unfortunately the tensioner and some of the shaft dampeners are out of stock. Good news is I have a while before I have to have them.
'77 KZ1000-MTC 1075 kit. Stage 1 port
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- fordtruck
- jeffasaki
- Thank you received: 44
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- mtkawboy
- Thank you received: 16
- savedrider
- 1975 Z1-B 900
Get right or get left! <*{{{><
- bountyhunter
- Thank you received: 337
That took me at least four hours on mine. Kawi factory ses some kind of permanent sealer on it.I spent the afternoon scraping what was left of my base gasket of the cases. Boy that stuff is like concrete!
- bountyhunter
I think that works on gasket material but not the sealer the factory used on base gaskets which is similar to 3-bond. It is NOT designed to ever be removed. It bonded the surfaces of the gasket so permanently, I could not get the cylinder to move until I was able to tear the gasket itself apart from the middle with half still glued to each surface (cylinder and crankcase). That is permanenet sealer.there is a lovely product made by permatex called gasket remover try that it softens up old gaskets quite well it doesnt remove them completly but it will soften them up enough to be able to remove easier.
- Jeff.Saunders
www.z1enterprises.com
Z1 Ent on Facebook,
- 9am53
- homebrew, and some bbq
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
- bountyhunter
Yep, that's the way I got mine off. Single sided razor. Then I use scotchbrite pad to srub the surface dead clean and wipe with acetone.I found after much effort that holding a razor vertically and scraping the gasket off that way works well.
- Jack
- Thank you received: 7
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
