Present in OIL PAN
- KLD
25 Jan 2010 19:46 - 25 Jan 2010 19:47 #344579
by KLD
Present in OIL PAN was created by KLD
Last edit: 25 Jan 2010 19:47 by KLD.
- trianglelaguna
- Thank you received: 235
25 Jan 2010 20:04 #344583
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Replied by trianglelaguna on topic Present in OIL PAN
could you post a clearer pic...it would be hard for a broken friction plate to travel down to the pan i think....clearer pics would help...it does look like the edges are part of a disk shape and the material seems to match what a friction disk in your clutch looks like..
1976 KZ900
2003 ZX12R
2007 FZ1000
- KLD
25 Jan 2010 20:44 #344590
by KLD
Replied by KLD on topic Present in OIL PAN
- MFolks
- Thank you received: 540
25 Jan 2010 21:51 #344601
by MFolks
Replied by MFolks on topic Present in OIL PAN
I'd pull the clutch cover off and do an inspection myself.
- Bluemeanie
- Thank you received: 14
25 Jan 2010 21:57 - 25 Jan 2010 22:01 #344602
by Bluemeanie
Replied by Bluemeanie on topic Present in OIL PAN
I cropped and tried to adjust the image some so it would help. Are those by chance broken ears off the clutch basket?
Last edit: 25 Jan 2010 22:01 by Bluemeanie.
- testarossa
- Thank you received: 82
26 Jan 2010 04:31 #344608
by testarossa
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
Replied by testarossa on topic Present in OIL PAN
I'm gonna say that this is part of a friction disk. I would definantly pull the clutch cover. All it will cost you is one gasket.
2004 ZX-10R
Angola, IN
- Old Man Rock
- Thank you received: 225
26 Jan 2010 04:52 #344611
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic Present in OIL PAN
Those have the vertical lines of a friction plate but they seem fairly thick for that...
Clutch basket finger, possibly...
Sucks Blue... As the unfortunate saying goes... Only one way to know for sure.... :pinch: Open her up!
Definitely let us know what you find for future references....
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- trianglelaguna
26 Jan 2010 06:02 #344624
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
yep...that be the clutch bob..final answer...get a gasket and it is a good time to put new friction plate set...and new stock springs..the metal plates that make the other half of the set usualy are good to re-use ,no problem....i prefer heavy duty springs but they can work cables down quicker and some folks don't like the added force they make you use to pull the lever in...but new plates and new stock springs and a gasket and you'll be fine...i shatterd a plate doing a burnout and it felt like i blew my tranny(i was a kid) but it was just one friction plate that broke into little pieces....does your bike seem to still drive...anyway...it may be a p.o who fixed the plates and left you a present in the pan?
IT IS THE FRICTION PLATES CHUNKS IN YOUR PICS
1976 KZ900
2003 ZX12R
2007 FZ1000
- zed1015
- Thank you received: 1556
26 Jan 2010 06:16 - 26 Jan 2010 06:19 #344632
by zed1015
Replied by zed1015 on topic Present in OIL PAN
Yep! Definately the clutch friction plate tangs gone walkabout.
Last edit: 26 Jan 2010 06:19 by zed1015.
- PLUMMEN
- Thank you received: 104
26 Jan 2010 07:38 #344651
by PLUMMEN
- timebomb33
26 Jan 2010 08:17 #344656
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Present in OIL PAN
it's a couple of pieces of your i would say, inside fiber plates on my drag bike break quite frequently so i'm very used to seeing what your seeing when they break on mine it is always the inside two. not a big problem just replace the broken plates and your ready to go again.
- TerryK
- Thank you received: 3
26 Jan 2010 09:15 #344660
by TerryK
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
Replied by TerryK on topic Present in OIL PAN
Clutch plate no doubt. I had 5 times that much in my pan once and the clutch still worked fine lol. A quick rebuild and you'll be good to go.
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
