Present in OIL PAN
  • KLD
  • KLD's Avatar Topic Author
Present in OIL PAN
25 Jan 2010 19:46 - 25 Jan 2010 19:47
#344579
Any idea what this is? Its aluminum and is broken on the sides, It seems to have a gasket like material on it. Is this broken clutch?
The motor is a 73 z1.
[IMG
Last edit: 25 Jan 2010 19:47 by KLD.
  • trianglelaguna
  • trianglelaguna's Avatar
Re: Present in OIL PAN
25 Jan 2010 20:04
#344583
could you post a clearer pic...it would be hard for a broken friction plate to travel down to the pan i think....clearer pics would help...it does look like the edges are part of a disk shape and the material seems to match what a friction disk in your clutch looks like..
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • KLD
25 Jan 2010 20:44
#344590
  • MFolks
  • MFolks's Avatar
25 Jan 2010 21:51
#344601
I'd pull the clutch cover off and do an inspection myself.
  • Bluemeanie
  • Bluemeanie's Avatar
25 Jan 2010 21:57 - 25 Jan 2010 22:01
#344602
I cropped and tried to adjust the image some so it would help. Are those by chance broken ears off the clutch basket?
Last edit: 25 Jan 2010 22:01 by Bluemeanie.
  • testarossa
  • testarossa's Avatar
26 Jan 2010 04:31
#344608
I'm gonna say that this is part of a friction disk. I would definantly pull the clutch cover. All it will cost you is one gasket.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • Old Man Rock
  • Old Man Rock's Avatar
26 Jan 2010 04:52
#344611
Those have the vertical lines of a friction plate but they seem fairly thick for that...
Clutch basket finger, possibly...
Sucks Blue... As the unfortunate saying goes... Only one way to know for sure.... :pinch: Open her up!
Definitely let us know what you find for future references....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • trianglelaguna
26 Jan 2010 06:02
#344624
yep...that be the clutch bob..final answer...get a gasket and it is a good time to put new friction plate set...and new stock springs..the metal plates that make the other half of the set usualy are good to re-use ,no problem....i prefer heavy duty springs but they can work cables down quicker and some folks don't like the added force they make you use to pull the lever in...but new plates and new stock springs and a gasket and you'll be fine...i shatterd a plate doing a burnout and it felt like i blew my tranny(i was a kid) but it was just one friction plate that broke into little pieces....does your bike seem to still drive...anyway...it may be a p.o who fixed the plates and left you a present in the pan?
IT IS THE FRICTION PLATES CHUNKS IN YOUR PICS
1976 KZ900
2003 ZX12R
2007 FZ1000
  • zed1015
  • zed1015's Avatar
26 Jan 2010 06:16 - 26 Jan 2010 06:19
#344632
Yep! Definately the clutch friction plate tangs gone walkabout.
Last edit: 26 Jan 2010 06:19 by zed1015.
  • PLUMMEN
  • PLUMMEN's Avatar
26 Jan 2010 07:38
#344651
  • timebomb33
  • timebomb33's Avatar
26 Jan 2010 08:17
#344656
it's a couple of pieces of your i would say, inside fiber plates on my drag bike break quite frequently so i'm very used to seeing what your seeing when they break on mine it is always the inside two. not a big problem just replace the broken plates and your ready to go again.
I THINK MY POWERBAND BROKE
  • TerryK
  • TerryK's Avatar
26 Jan 2010 09:15
#344660
Clutch plate no doubt. I had 5 times that much in my pan once and the clutch still worked fine lol. A quick rebuild and you'll be good to go.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
