How see the color codes on crank and rod bearings?
  • Arnold
  • Arnold's Avatar Topic Author
11 Nov 2009 12:55 - 14 Nov 2009 10:23
#332879
Hi KzRiders !
How do I see the color codes or marks for the rod and crank bearings ?
You can see from the photo that the nuts are painted brown on the rods. I assume that these are coded BROWN ?
But where do I find the codes for the crank bearings ?
My bike is a KZ750-E3 1982 (US)
/Arnold
[img size=(01-499)]H:\My Documents\My Pictures\Z750\Kawa 750 Crank.jpg[/img]
Last edit: 14 Nov 2009 10:23 by Arnold.
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: How see the color codes on crank and rod bearings?
11 Nov 2009 15:03
#332893
I'm a bit confused...there are no color codes for bearings/bearing nuts. For the connecting rod bearings, there are three active Kawasaki numbers (two partials and a complete active...all substitute for each other, according to Kawasaki). The Kawasaki numbers for the crank bearings can be found at www.kawasaki.com under your bike... :huh:
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • keith1
  • keith1's Avatar
11 Nov 2009 15:24
#332899
and i thought i was the only guy going"wtf?".....:laugh:
11 Nov 2009 19:49
#332999
I can't speak for the KZ750, but the KZ650C1 parts manual shows 3 different part numbers for connecting rod bearings depending on the color. 13034-50 - Blue; 13034-51 - Black; 13034-52 - Brown. Ed
  • Arnold
12 Nov 2009 01:17
#333054
Hi again,
It should be the same thing for the KZ750.
According to Kawasaki.com there are 3 different rod bearings that fit the KZ750-E3:
13034-050
13034-051
13034-052
If you search these numbers at Bikebandit.com you get the color codes, just as stated in the work shop manual.
13034-50 - Blue
13034-51 - Black
13034-52 - Brown
My question is if I got the "brown" color code right from the rodnuts ?
And where do I find the code for the crank bearing ?
  • hardr0ck68
  • hardr0ck68's Avatar
  • Who put the what in the where?
12 Nov 2009 03:47
#333066
It was posted on this forum (Steell I think said it) that the colors corresponded to sizes. If you hunt around I am sure you can find the old thread... I will take a look after work if no one else posts the information.
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
  • hardr0ck68
12 Nov 2009 03:55 - 12 Nov 2009 03:58
#333068
It was Steell , he was helpful and in the know...to bad not all members are so useful.
::EDIT:: These bearings numbers are for a 750 twin, that is why the numbers do not match... I would think the thicknesses would also be incorrect for a 650/750 4 cylinder, but still it show how Kawisaki used the color/size system ::/EDIT::
he posted this,
Bearimg insert thickness:
Blue - 1.485~1.490 mm . . PN 13034-045
Black - 1.480~1.485 mm . .PN 13034-043
Brown - 1.475~1.480 mm . .PN 13034-046
comes from this thread
kzrider.com/index.php?option=com_kunena&...tid=2&id=43260#43302
1977 kz650 c1
Last edit: 12 Nov 2009 03:58 by hardr0ck68.
  • Arnold
12 Nov 2009 04:31 - 12 Nov 2009 05:34
#333070
Thanx Hard,
I´m 95 % sure that I need the "brown" shells/bearings for the rod wich is partnumber 13034-052.
The 5 % I´m not sure of is if there is a different color marking somewhere else. I mean, the brown color on my nuts :) could have come from someone who messed around years ago. It could have been some kind of Lock Tite / Studlock wich leaves a brown coloc, who knows ?
Steell also mentions the marking of "1" or "unmarked" for the crank shells.
BUT EXACTLY WERE DO I FIND THIS MARK ON THE CASE ?
Last edit: 12 Nov 2009 05:34 by Arnold.
  • Arnold
12 Nov 2009 11:45 - 27 Nov 2009 10:52
#333134
Found it !
Inside the lower part of the case on the front side.
One bearing was marked "1" the rest unmarked.
EDIT !!!
This mark has nothing to do with crank bearing size
/Arnold 27/11-2009
Last edit: 27 Nov 2009 10:52 by Arnold.
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
12 Nov 2009 12:56
#333145
Which is why I like this site...I learn something new every day. :laugh:
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • keith1
  • keith1's Avatar
12 Nov 2009 14:28
#333155
yep.....dont have any experience with the smaller cc's...i forget that they dont ride on the roller/ball bearings on the bottom end ....:blush:
  • gane
  • gane's Avatar
14 Nov 2009 19:40
#333726
Arnold, the color of your' nuts is inconcequencial. In plain bearing cranks the bearings will sometimes have the residuals of color on the sides of bearing inserts. on un-molested engines there will be a series of #'s embossed on the crank's internal flyweight at cam chain sprocket. 5 digits indicating main dia's 4 indicating rod dia's.(left to right) at rear of case, a series of 5 #'s indicating case bearing sizes. rods will have assigned #'s.one for size, another for weight. your' shop manual will include a quick check for sizing. unless you've experianced a failure or can see copper babbit in bearings or are building a performance motor, let sleeping dogs lie. the only time a plain bearing sees contact is at start-up before oil presure arrives, and wear is only critical if wear allows a drop in oil pressure. If you plan on Going "BIG" or High reving, suggjest replacing rod bolts & nuts if disturbed. luck G
[img][/img] 1977 KZ1000A1
