- Thank you received: 5
finally putting 810 motor back together
- jordan
13 Oct 2009 08:57 #327296
by jordan
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold
1972 Kawasaki s2 350-parted on ebay
1973 Kawasaki s2 350-parted on ebay
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
Replied by jordan on topic finally putting 810 motor back together
ok, i will check those things when the motor is back in one piece. i checked for the noise and catching by turning it over manually, and came up with nothing. only is noticeable when the motor is fired up
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- mark1122
- Keep twisting it
- Thank you received: 109
13 Oct 2009 11:15 #327320
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic finally putting 810 motor back together
is the motor together now , or apart?
if apart, u really need to measure everything. rod ends in particular. and piston pin holes .piston to wall. u can measure a valve for bend, by placing it in a v block and set up a dial indicator on the big end, then just rotate the valve. the do the same on the shaft.
u can measure the head to piston clearance with solder. place 2 pieces through the spark plug hole. align each piece over a wrist pin , then turn the piston past tdc to mash the solder.
start with thin solder if can find some around .040" .060".
then u measure the thickness of the flattened solder.
if it does not touch then u have plenty of clearance.
Yes cam chains stretch. hense the adjuster.:lol:
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- tjk
13 Oct 2009 11:35 #327330
by tjk
FIDO
Replied by tjk on topic finally putting 810 motor back together
...and cam chains will stretch beyond the reach of a stock tensioner...
Gotta love the jack-offs in the shop class...had to deal some bastards like that in tech school, sabotage, theft, taking engines partially apart to check for high-performance vs. stock parts (came in one day to find the cam pulled out of my 350 just far enough to read "GM" on it...)
FIDO
