- Thank you received: 5
finally putting 810 motor back together
- jordan
right now i have both motors dowm to the bottom end, am putting the 810 pistons onto the other bottom end. i noticed that one piston pin was very hard to get out. I had to beat it out, and moves in and out VERY hard. could this cause any sort of knock?
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold
1972 Kawasaki s2 350-parted on ebay
1973 Kawasaki s2 350-parted on ebay
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
- Thank you received: 2829
- jordan
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- PLUMMEN
- Thank you received: 104
was it sticking in the piston or the rod end? did you notice any slop in piston if you try twisting towards end of wristpin?well after way to long without a rideable bike, and 2 topend rebuilds i am still clueless on why my bike has a loud knock. Fixing sometihng when you are unsure of the source of the problem is getting very aggrevating. The knock seems to be coming from the topend, when using a screwdriver to find the source of the noise. every motorcycle shop around my area said it was definately a bent valve, but i was unsure. the first rebuild i put on the kz head that was on my motor originally before i put on the gpz head. got it all back together and still the same annoying knock. second rebuild i dissassembled the topend adn checked everything for wear, used new shims, and checked the pistons for any damage. Then played with the advance/retard settings on my ignition. Still had the same annoying knock. The other thing that really bothers me about it is that it didnt seem to lose any power after it developed the knock. So now i am starting the final rebuild with a completely different bottom end (dont know why, but any change will make me feel better) my gpz head, and the kz cams(is it possible that my gpz cams could be bent?
- jordan
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- PLUMMEN
- jordan
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- PLUMMEN
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
- Thank you received: 3
What is the piston deck height?
- jordan
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- Bluemeanie
- Thank you received: 14
never checked rod/main bearings or piston deck height, but the valves looked untouched by the pistons. The bike always ran great. took it to the dragstrip one weekend, ran fine all week, i put wiped down teh clutch disks with emery cloth, put it all back together, rode it a while, then the next weekend it started ticking. checked the clutch immediately, but evetything looked perfect
So if I understand correctly, the noise stopped after you wiped down the clutch discs, then came back? If so I think you found the area of the noise.
- gearhead119
2000 Zrx1100 Turbo-220bhp/145lbs torque
1978 KZ 1000 project-in progress
