- Thank you received: 225
'77 KZ650 won't go into 1st gear at a stop
- Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- Kawickrice
- Thank you received: 18
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
- Old Man Rock
Just having a little fun... :blush:
Seems to some of us you'll need to re-adjust your cable and clutch push rod to spec...
If you feel energetic, open up and measure your clutch plates and springs for specification verifications.
If you need the procedure, let us know....
OMR
Here's the KZ900 clutch adjustment procedure just in case... Should be close to the same as your KZ650... Others can chime in....
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Old Man Rock
At least it will give you an idea of what to look for in the procedure itself....
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Thank you received: 2098
- Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- RonKZ650
- Thank you received: 240
- Old Man Rock
Once he gets the bike moving ever so slightly, it has enough plate catch to get her rolling along....
Thus first thing to check for me anyways would be my clutch/push rod adjustments. If that didn't work out then check my plate and springs for out of tolerances specifications...
One sure method of checking if truly going into gear...
Raise the rear, while in neutral spin the rear tire... Acknowledge the resistance in the spin...
Without the clutch, down shift into first gear, try and rotate the tire by hand... That gear, chain, tire should be locked up, no spin what so ever... Even with a little muscle, that tire should not spin...
If it still spins but you have heavy resistance where your really having a hell of a time versus compared to neutral spin, then clutch most likely still engaged.
Close the clutch adjustments at the handle bar lever and mid cable adjusters. Loosen the lock nut on the clutch side cover and back out the screw CCW a turn or two.
Now try and rotate the tire... If the clutch plates are compressing together to specifications, this tire should not rotate...
If it does, then go after the friction plate thickness and springs for they are most likely out of spec.... Meaning the friction have worn thin, the springs don;t compress out to full height. Possibly as in my case the steel plates were warped out of spec.
Just my thoughts on the problem.... good luck!
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Locozuna
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
- kawsakiman
- Thank you received: 6
just pull the clutch once or twice before you shift down.
what is happening is your tranny is landing right on top of the dogs, which are more then likely a little worn.
when you have the clutch pulled in, the tranny is not turning so it's resting in that position. it can't engage in that position.
when you roll it a little you move the tranny gears and they line up a little better, then it will go right in gear.
when you pump the clutch in neutral it causes the tranny to spin, bringing them into a better position to drop in.
hope this clears it up for you.
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- ckotul
i know what's going on and how to solve it without a Major teardown.
This worked perfectly! Thanks for the tip, it was driving me crazy!
1977 KZ650C1
