'77 KZ650 won't go into 1st gear at a stop
- ckotul
22 Sep 2009 12:07 #323250
by ckotul
1977 KZ650C1
'77 KZ650 won't go into 1st gear at a stop was created by ckotul
Whenever I come to a complete stop in neutral on my '77 KZ650, I can't get it into 1st gear without rolling the bike a little. I thought it was just the clutch, but I just had it replaced and it's still doing it. Is this normal?
Thanks!
Thanks!
1977 KZ650C1
- YUKABODOS
22 Sep 2009 12:29 #323253
by YUKABODOS
Replied by YUKABODOS on topic '77 KZ650 won't go into 1st gear at a stop
It is normal. As far as I know it happens with a lot of bikes. I usually roll mine about a foot and it drops into gear.
- baldy110
- Thank you received: 512
22 Sep 2009 13:10 #323263
by baldy110
Replied by baldy110 on topic '77 KZ650 won't go into 1st gear at a stop
That is normal. Most bikes do not use synchros in the tranny so they all do that. Don't worry about it.
- Locozuna
22 Sep 2009 13:20 #323266
by Locozuna
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
Replied by Locozuna on topic '77 KZ650 won't go into 1st gear at a stop
Not normal on my bikes. Not neutral to first anyway. :huh:
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
- Old Man Rock
- Thank you received: 225
22 Sep 2009 13:42 #323270
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic '77 KZ650 won't go into 1st gear at a stop
Can't speak for the KZ650 but for KZ900... Not normal...
It would be normal not to be able to shift above 2nd at a dead stop but to first....
Bluemeanie and kawasakiman have KZ650's as well, ask them for this doesn't seem right where you'd have to roll it a foot for 1st engagement.... Maybe I'm wrong....:blush:
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- RonKZ650
- Thank you received: 240
22 Sep 2009 14:56 #323283
by RonKZ650
Replied by RonKZ650 on topic '77 KZ650 won't go into 1st gear at a stop
All mine go right into first from neutral. I always shift to neutral at stops and just tap down and they go right in gear.
- bill_wilcox100
22 Sep 2009 15:00 #323284
by bill_wilcox100
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Replied by bill_wilcox100 on topic '77 KZ650 won't go into 1st gear at a stop
I have a '77 KZ650-B1... it always goes into 1st gear from neutral... it may clunk hard, but it always goes in gear.
In my case, if it does not go into gear then my clutch is not adjusted correctly. It needs adjustment to separate the clutch plates more when the clutch lever is all the way in.
First, I'd suspect improper adjustments and second, tired clutch cables or cable housings that are stretching when pulled so as to prevent the clutch plates from fully separating.
Best of success.
Bill
Best of success.
Bill
Upgrades:
Montreal, Canada
- Old Man Rock
22 Sep 2009 18:22 #323357
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- keith1
22 Sep 2009 18:32 #323360
by keith1
Replied by keith1 on topic '77 KZ650 won't go into 1st gear at a stop
that puppy is smokin'....she be jetted right dave?....
- Old Man Rock
22 Sep 2009 18:36 #323363
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Naw... still burning a little on the rich side....
Damn Gunson Carb tuner....
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Thank you received: 2829
22 Sep 2009 18:49 #323367
by 650ed
Replied by 650ed on topic '77 KZ650 won't go into 1st gear at a stop
My '77 KZ650C1 has always shifted from neutral to 1st at a dead stop with no problem other than a bit of a "clunk." I'm betting your clutch needs adjustment. The Kawasaki factory service manual describes how to do this correctly. Do you have this manual for your bike? Ed
- Locozuna
22 Sep 2009 18:51 - 22 Sep 2009 18:53 #323368
by Locozuna
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
Last edit: 22 Sep 2009 18:53 by Locozuna.
