'77 KZ650 won't go into 1st gear at a stop
22 Sep 2009 12:07 #323250 by ckotul
Whenever I come to a complete stop in neutral on my '77 KZ650, I can't get it into 1st gear without rolling the bike a little. I thought it was just the clutch, but I just had it replaced and it's still doing it. Is this normal?
Thanks!
1977 KZ650C1
22 Sep 2009 12:29 #323253 by YUKABODOS
Replied by YUKABODOS on topic '77 KZ650 won't go into 1st gear at a stop
It is normal. As far as I know it happens with a lot of bikes. I usually roll mine about a foot and it drops into gear.
22 Sep 2009 13:10 #323263 by baldy110
Replied by baldy110 on topic '77 KZ650 won't go into 1st gear at a stop
That is normal. Most bikes do not use synchros in the tranny so they all do that. Don't worry about it.
22 Sep 2009 13:20 #323266 by Locozuna
Replied by Locozuna on topic '77 KZ650 won't go into 1st gear at a stop
Not normal on my bikes. Not neutral to first anyway. :huh:
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
22 Sep 2009 13:42 #323270 by Old Man Rock
Replied by Old Man Rock on topic '77 KZ650 won't go into 1st gear at a stop
Can't speak for the KZ650 but for KZ900... Not normal...
It would be normal not to be able to shift above 2nd at a dead stop but to first....
Bluemeanie and kawasakiman have KZ650's as well, ask them for this doesn't seem right where you'd have to roll it a foot for 1st engagement.... Maybe I'm wrong....:blush:
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
22 Sep 2009 14:56 #323283 by RonKZ650
Replied by RonKZ650 on topic '77 KZ650 won't go into 1st gear at a stop
All mine go right into first from neutral. I always shift to neutral at stops and just tap down and they go right in gear.
22 Sep 2009 15:00 #323284 by bill_wilcox100
Replied by bill_wilcox100 on topic '77 KZ650 won't go into 1st gear at a stop
I have a '77 KZ650-B1... it always goes into 1st gear from neutral... it may clunk hard, but it always goes in gear.
In my case, if it does not go into gear then my clutch is not adjusted correctly. It needs adjustment to separate the clutch plates more when the clutch lever is all the way in.
First, I'd suspect improper adjustments and second, tired clutch cables or cable housings that are stretching when pulled so as to prevent the clutch plates from fully separating.
Best of success. :)
Bill
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
22 Sep 2009 18:22 #323357 by Old Man Rock
Wait a minute...
You guys must have the Fred Flintstone model....:blink:
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
22 Sep 2009 18:32 #323360 by keith1
Replied by keith1 on topic '77 KZ650 won't go into 1st gear at a stop
that puppy is smokin'....she be jetted right dave?....
22 Sep 2009 18:36 #323363 by Old Man Rock
Naw... still burning a little on the rich side....
Damn Gunson Carb tuner....
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
22 Sep 2009 18:49 #323367 by 650ed
Replied by 650ed on topic '77 KZ650 won't go into 1st gear at a stop
My '77 KZ650C1 has always shifted from neutral to 1st at a dead stop with no problem other than a bit of a "clunk." I'm betting your clutch needs adjustment. The Kawasaki factory service manual describes how to do this correctly. Do you have this manual for your bike? Ed
22 Sep 2009 18:51 - 22 Sep 2009 18:53 #323368 by Locozuna
Wilma fell off........again :lol:
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
Last edit: 22 Sep 2009 18:53 by Locozuna.
