I'm baffled, now
  • loudhvx
  • Topic Author
13 Aug 2009 09:55 - 21 Nov 2019 08:10 #313649 by loudhvx
I'm baffled, now was created by loudhvx
Making a Kerker knock-off baffle. I'm, making it similar to a Kerker K series muffler. The canister is a Kerker or Kerker knock off, but it is beat up from years of track duty. I got it with no baffle, so here it goes. (Also, just starting to learn how to weld with flux core MIG, man is it messy... wish I had my Oxy-A rig... slower, but neater.)
First the screen. I bought it at Menards. It's expensive, so if anyone wants some, I have most of it still left over I can sell.
It forms really easily around a pipe in a vice.
Attachment RolledScreen.jpg not found
Last edit: 21 Nov 2019 08:10 by loudhvx.
  • loudhvx
  • Topic Author
13 Aug 2009 09:57 - 21 Nov 2019 08:13 #313651 by loudhvx
Replied by loudhvx on topic I'm baffled, now
Next, found some old rollers at work that were close to the right diameter for pipe stock.
Attachment PipeStock.jpg not found
Last edit: 21 Nov 2019 08:13 by loudhvx.
  • loudhvx
  • Topic Author
13 Aug 2009 09:58 - 21 Nov 2019 08:13 #313654 by loudhvx
I made a nozzle out of the end of the pipe.
Attachment NozzleCutout.jpg not found
  • loudhvx
  • Topic Author
13 Aug 2009 09:59 - 21 Nov 2019 08:15 #313655 by loudhvx
Cut and weld the nozzle to the screen.
Attachment NozzleWelded.jpg not found
Last edit: 21 Nov 2019 08:15 by loudhvx.
  • loudhvx
  • Topic Author
13 Aug 2009 10:01 - 21 Nov 2019 08:16 #313656 by loudhvx
Welded on a tailpipe to the nozzle outlet.
Attachment NozzleTailPipe.jpg not found
Last edit: 21 Nov 2019 08:16 by loudhvx.
13 Aug 2009 10:01 #313657 by irishwill
Replied by irishwill on topic I'm baffled, now
KEWL!!!
  • loudhvx
  • Topic Author
13 Aug 2009 10:02 - 21 Nov 2019 08:20 #313658 by loudhvx
The tailpipe will fit into the center of the end-cap doughnut.
Attachment TailPipeIntoCap.jpg not found
Last edit: 21 Nov 2019 08:20 by loudhvx.
  • loudhvx
  • Topic Author
13 Aug 2009 10:04 - 21 Nov 2019 08:28 #313659 by loudhvx
EDIT: I originally went with a tube within a tube design for the exit to make the baffle more stable. But it was heavy, so I removed it and later just put a stop ring on the pipe to stop the baffle from sliding backward. The following three photos are of the first design.
Attachment SupportSleeve.jpg not found
Last edit: 21 Nov 2019 08:28 by loudhvx.
  • loudhvx
  • Topic Author
13 Aug 2009 10:05 - 21 Nov 2019 08:29 #313662 by loudhvx
Attachment SupportSleeveWelded1.jpg not found
Last edit: 21 Nov 2019 08:29 by loudhvx.
  • loudhvx
  • Topic Author
13 Aug 2009 10:05 - 21 Nov 2019 08:30 #313663 by loudhvx
Another shot
Attachment SupportSleeveWelded2.jpg not found
Last edit: 21 Nov 2019 08:30 by loudhvx.
  • loudhvx
  • Topic Author
13 Aug 2009 10:08 - 21 Nov 2019 08:31 #313664 by loudhvx
Now the other end is rougher. The canister is mangled, so the entrance to the baffle has to have a wierd shape to it. If I get a new canister somewhere, I'll have to cut off the entrance and weld on a nicer one.
Attachment EntranceTaper.jpg not found
Last edit: 21 Nov 2019 08:31 by loudhvx.
  • loudhvx
  • Topic Author
13 Aug 2009 10:09 - 21 Nov 2019 08:47 #313667 by loudhvx
I was going to weld the slits, but then realized brazing would do a better job here. The MIG tends to burn open slits into large holes.
EDIT: I'd probably weld it now, having had more time with the mig.
Attachment EntranceBrazed.jpg not found
Last edit: 21 Nov 2019 08:47 by loudhvx.
