- Thank you received: 2098
Kevlar Clutch Discs? Anyone?
30 Jul 2009 02:09 #310306
by Patton
Replied by Patton on topic Kevlar Clutch Discs? Anyone?
550A2 wrote:
The other adjustment is clutch pushrod sdjustment.
Good Luck!
...I know the clutch is slipping because the adjusters are in as far in as they can go without exessive slack in the cable.
unless there is another adjustment?....
Good Luck!
- Old Man Rock
- Thank you received: 225
30 Jul 2009 05:28 #310317
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic Kevlar Clutch Discs? Anyone?
Just out of curisoity and maybe I missed it so I'll ask anyways...
In your shop manual, there should be a well defined section for specifications in measuring your clutch plates and springs with a caliper. Are they out of spec?
There's a trick I learned from Larry and Plummen, insert a spark plug washer on the springs behind the pressure plate for this will also add a little extra pressure thus plate bites...
I posted an image in my project file...
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
